How to set "ESP_PLATFORM" to 1 in Custom CMake Projects
Serdar
Postby Serdar » Wed Feb 22, 2023 2:56 am
Hi, i have a similar project to this. I used tinyUSB inside this project.
https://github.com/espressif/esp-idf/tr ... idf_as_lib
After get this warning I realized that ESP_PLATFORM is 0
warning: implicit declaration of function 'traceISR_EXIT_TO_SCHEDULER' [-Wimplicit-function-declaration]
void app_main(void)
    #if defined(ESP_PLATFORM)
    ESP_LOGI(TAG, "ESP_PLATFORM_Definded");
    #else
    ESP_LOGE(TAG, "ESP_PLATFORM_NOT_Definded");//code goes here
    #endif /*ESP_PLATFORM*/
I tried these to make ESP PLATFORM 1
/build-esp32s3.sh
#!/usr/bin/env bash
set -euo pipefail
PARAM=""
# Retrive the target from the current filename, if no target specified,
# the variable will be empty
TARGET=$(echo $0 | cut -s -f2 -d- | cut -s -f1 -d.)
if [[ -n $TARGET ]]
then
    # Target is not null, specify the build parameters
    PARAM="-DESP_PLATFORM=1 -DCMAKE_TOOLCHAIN_FILE=$IDF_PATH/tools/cmake/toolchain-${TARGET}.cmake -DTARGET=${TARGET} -GNinja"
fi
rm -rf build && mkdir build && cd build
cmake .. $PARAM
cmake --build .
But that didn't work.
/CMakeLists.txt
set(ESP_PLATFORM  ON)
But that didn't work too
How can I make ESP_PLATFORM set to 1 ?
Have a nice day!
-Serdar
Bob
Re: How to set "ESP_PLATFORM" to 1 in Custom CMake Projects
Postby Bob » Tue Feb 20, 2024 3:55 am
IDF provide a simple cmake function `idf_build_set_property`, Please refer https://github.com/espressif/esp-idf/bl ... #L620-L621
Users browsing this forum: Bytespider, ChatGPT-User, Semrush [Bot] and 3 guests
