will take a small time(day) frame, i come back to this with the log you need.
rudi
@ESP_Stanza
@johnlee
@ESP_igrr
please help to this never ending story now
Q: why this exampe run on Wrover 32MBit_1.8/32MBit_1.8 modul ( SoC Rev 0 )
but not on the custom 64MBit_wide/32MBit_1.8 ( SoC Rev 0 )
Q: the 64MBit is wide flash ( 1.8 .. 3.6 V ) and works with 1.8 and 3.3 - is there a problem with 1.8 driven wide flash and combine 1.8 psram?
Q: we use Lyontek PSRAM, is there a magic key for psram ( ESP-PSRAM32 ) ID and if this not match the PSRAM is not supported?
Q: is there a hidden/not knowed detail on HDK that we not know? ( missing the edited wrover shematic file - can u post now ? )
Q: we need the HDK wrover shematic with BOM like the WROOM32 modul.
rudi![]()
if (((id >> PSRAM_MFG_ID_S) & PSRAM_MFG_ID_M) != PSRAM_MFG_ID_ESPRESSIF) {
return ESP_FAIL;
--- idf_monitor on /dev/ttyUSB0 115200 --- --- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H --- ets Jun 8 2016 00:22:57 rst:0x1 (POWERON_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT) ets Jun 8 2016 00:22:57 rst:0x10 (RTCWDT_RTC_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0x00 clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0008,len:4 load:0x3fff000c,len:4540 load:0x40078000,len:12428 ho 0 tail 12 room 4 load:0x40080000,len:268 0x40080000: _iram_start at ??:? entry 0x40080034 0x40080034: _iram_start at ??:? I (47) boot: ALB-ESP32x64[0]-IDF v2.0-rc1-892-gded1cd3-dirty 2nd stage bootloader I (47) boot: compile date Jul 6 2017 I (54) boot: compile time 19:12:31 I (66) boot: by rudi ;-) TEST-SOP-OK? : I (7871) boot: input now character h I (11913) boot: Enabling RNG early entropy source... I (11913) boot: SPI Speed : 40MHz I (11913) boot: SPI Mode : DIO I (11922) boot: SPI Flash Size : 8MB I (11935) boot: Partition Table: I (11947) boot: ## Label Usage Type ST Offset Length I (11971) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (11994) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (12018) boot: 2 factory factory app 00 00 00010000 00100000 I (12042) boot: End of partition table I (12056) boot: Disabling RNG early entropy source... I (12073) boot: Loading app partition at offset 00010000 I (12611) boot: segment 0: paddr=0x00010018 vaddr=0x00000000 size=0x0ffe8 ( 65512) I (12612) boot: segment 1: paddr=0x00020008 vaddr=0x3f400010 size=0x071b0 ( 29104) map I (12629) boot: segment 2: paddr=0x000271c0 vaddr=0x3ffb0000 size=0x022f4 ( 8948) load I (12660) boot: segment 3: paddr=0x000294bc vaddr=0x40080000 size=0x00400 ( 1024) load 0x40080000: _iram_start at ??:? I (12683) boot: segment 4: paddr=0x000298c4 vaddr=0x40080400 size=0x14a34 ( 84532) load I (12750) boot: segment 5: paddr=0x0003e300 vaddr=0x400c0000 size=0x00000 ( 0) load I (12751) boot: segment 6: paddr=0x0003e308 vaddr=0x00000000 size=0x01d00 ( 7424) I (12769) boot: segment 7: paddr=0x00040010 vaddr=0x400d0018 size=0x2aba8 (175016) map 0x400d0018: _flash_cache_start at ??:? PSRAM enable was here: 1 we start now to test the psram, press key [0] : Read PSRAM ID Now, press key [1] :Guru Meditation Error of type IllegalInstruction occurred on core 0. Exception was unhandled. Register dump: PC : 0x400d1b6d PS : 0x00060530 A0 : 0x80082599 A1 : 0x3ffe3be0 0x400d1b6d: psram_read_id at /mnt/Share/psram/esp-idf-psram/components/esp32/./psram.c:347 A2 : 0x3ffe3c30 A3 : 0x00000023 A4 : 0x00000004 A5 : 0x00000000 A6 : 0x00000000 A7 : 0xfffffffe A8 : 0x00000001 A9 : 0x3ffe3b90 A10 : 0x00000001 A11 : 0x00000000 A12 : 0x00000034 A13 : 0x00000000 A14 : 0x00000000 A15 : 0x00000004 SAR : 0x00000017 EXCCAUSE: 0x00000000 EXCVADDR: 0x00000000 LBEG : 0x40094c1c LEND : 0x40094c4a LCOUNT : 0xffffffff 0x40094c1c: memset at /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memset.S:127 0x40094c4a: memset at /home/jeroen/esp8266/esp32/newlib_xtensa-2.2.0-bin/newlib_xtensa-2.2.0/xtensa-esp32-elf/newlib/libc/machine/xtensa/../../../../.././newlib/libc/machine/xtensa/memset.S:171 Backtrace: 0x400d1b6d:0x3ffe3be0 0x40082599:0x3ffe3c30 0x40080f62:0x3ffe3c60 0x40078861:0x3ffe3ca0 0x40078a88:0x3ffe3cd0 0x40079160:0x3ffe3d50 0x40080109:0x3ffe3e70 0x40007c34:0x3ffe3eb0 0x40000740:0x3ffe3f20 0x400d1b6d: psram_read_id at /mnt/Share/psram/esp-idf-psram/components/esp32/./psram.c:347 0x40082599: esp_restart_noos at /mnt/Share/psram/esp-idf-psram/components/esp32/./system_api.c:338 0x40080f62: call_start_cpu0 at /mnt/Share/psram/esp-idf-psram/components/esp32/./cpu_start.c:200 (discriminator 1) 0x40080109: _WindowOverflow12 at ??:? Rebooting... ets Jun 8 2016 00:22:57 rst:0xc (SW_CPU_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0x00 clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0008,len:4 load:0xcf3f00c3,len:4195567 1162 mmu set 00010000, pos 00010000 1162 mmu set 00020000, pos 00020000 1162 mmu set 00030000, pos 00030000 1162 mmu set 00040000, pos 00040000 1162 mmu set 00050000, pos 00050000 1162 mmu set 00060000, pos 00060000 1162 mmu set 00070000, pos 00070000 1162 mmu set 00080000, pos 00080000 1162 mmu set 00090000, pos 00090000 1162 mmu set 000a0000, pos 000a0000 1162 mmu set 000b0000, pos 000b0000 1162 mmu set 000c0000, pos 000c0000 1162 mmu set 000d0000, pos 000d0000 1162 mmu set 000e0000, pos 000e0000 1162 mmu set 000f0000, pos 000f0000 1162 mmu set 00100000, pos 00100000 1162 mmu set 00110000, pos 00110000 1162 mmu set 00120000, pos 00120000 1162 mmu set 00130000, pos 00130000 1162 mmu set 00140000, pos 00140000 1162 mmu set 00150000, pos 00150000 1162 mmu set 00160000, pos 00160000 1162 mmu set 00170000, pos 00170000 1162 mmu set 00180000, pos 00180000 1162 mmu set 00190000, pos 00190000 ets Jun 8 2016 00:22:57 rst:0x10 (RTCWDT_RTC_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0x00 clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0008,len:4 load:0x3fff000c,len:4540 load:0x40078000,len:12428 ho 0 tail 12 room 4 load:0x40080000,len:268 0x40080000: _iram_start at ??:? entry 0x40080034 0x40080034: _iram_start at ??:? I (47) boot: ALB-ESP32x64[0]-IDF v2.0-rc1-892-gded1cd3-dirty 2nd stage bootloader I (47) boot: compile date Jul 6 2017 I (54) boot: compile time 19:12:31 I (66) boot: by rudi ;-) TEST-SOP-OK?
ok thank you -I'm willing to give you an answer on this, but after the last fiasco, I want to be very very clear about one thing: Officially, we do NOT support any other chip than the ESP32 PSRAM. This means that officially we do NOT give out ANY support for this chip, at least not on this forum. That also means that any support you DO get is entirely given out of goodwill of the engineers hanging around this forum, not fact-checked, and can be wrong in any or all aspects. It also means that if you put this into a design and it doesn't work, it's not our problem.
Okay, with that said: the psram ID check is not the problem here. The bits of the ID that the code checks happens to be the same between the Lyontek PSRAM and the ESP32-PSRAM chip. Feel free to put a ets_printf when the check fails: you will not see it in the output.
I actually retrieved one of the Lyontek chips (didn't knew we had those) and reworked one of my ESP_Wrover_kit modules to take that instead of the module that was on there. With flash and PSRAM clocked at 40MHz, I have no problems and a stably-running Doom, and that is with the public psram esp-idf tree and Doom sources. With the flash running at 80MHz, the chip was less stable, it crashed within a few seconds where an ESP32-PSRAM would at the very least run for much longer.
Ok - thank you - then it must go.No, this test is done on a Rev1, with psram-as-malloc-able-memory. Aside from that, yes - normal Wrover module, got rid of the esp32-psram, soldered in the Lyontek part in the same footprint.
Yes - I see and think so too.At a glance, the schematic looks about right. My guess is that the 10K is only there so the RAM chip doesn't get accidentally enabled when the ESP32 is still booting up and GPIO16 is still Hi-Z.
Not really Jeroen - it's just like that.Just curious: Is there a specific reason you need to have Rev0 working?
ok jeroeni actually retrieved one of the Lyontek chips (didn't knew we had those) and reworked one of my ESP_Wrover_kit modules to take that instead of the module that was on there. With flash and PSRAM clocked at 40MHz, I have no problems and a stably-running Doom, and that is with the public psram esp-idf tree and Doom sources.
That Espressif at the earliest end August / Mid September (according to their information) again SoC Rev1 has available.
edit:
the wrover modul is also earliest available end of augus/ mid september then here
the psram are also not available, earliest end of august/ mid september
( sales " Eacen", and espressif itself )
edit:
I didn't hear about those dates yet.
Users browsing this forum: Baidu [Spider], PerplexityBot and 5 guests
