我的ESP32-C3出问题了
Moderator: XCGuang
bzxc41408
我的ESP32-C3出问题了
Postby bzxc41408 » Tue Feb 14, 2023 8:23 am
打印如下:
esptool.py v3.2-dev
Serial port COM13
Connecting...............................
WARNING: This chip doesn't appear to be a ESP32-C3 (chip magic value 0x1bb9506f). Probably it is unsupported by this version of esptool.
A fatal error occurred: Packet content transfer stopped (received 13 bytes)
* 终端进程“D:\Espressif\python_env\idf4.4_py3.8_env\Scripts\python.exe 'D:\Espressif\frameworks\esp-idf-v4.4\components\esptool_py\esptool\esptool.py', '-p', 'COM13', '-b', '460800', '--before', 'default_reset', '--after', 'hard_reset', '--chip', 'esp32c3', 'write_flash', '--flash_mode', 'dio', '--flash_freq', '80m', '--flash_size', 'detect', '0x0', 'bootloader/bootloader.bin', '0x10000', 'uart_events.bin', '0x8000', 'partition_table/partition-table.bin'”已终止,退出代码: 2。
该怎样解决?
esp-at
Re: 我的ESP32-C3出问题了
Postby esp-at » Fri Feb 24, 2023 4:37 am
先试试跟着文档,看是否能正常编译烧录 hello world 程序:https://docs.espressif.com/projects/esp ... index.html#
bzxc41408
Re: 我的ESP32-C3出问题了
Postby bzxc41408 » Fri Feb 24, 2023 6:32 am
感谢你的答复, 编译OK, 只是下载程序不成功。
Sun
Re: 我的ESP32-C3出问题了
Postby Sun » Fri Mar 03, 2023 11:23 am
可以更新下你的 esptool 工具版本哈
