ESP32 port not being seen by computer although having Silicon Labs CP2102 Driver
Zenith Fall
Postby Zenith Fall » Wed Mar 08, 2023 1:07 pm
Hello I'm very new to ESP32 and the world of micro-controllers.
I have ESP32 with me and the Silicon Labs Dual CP2105 USB to UART Bridge: Standard COM Port
driver installed.
And the port is not still being recognized. I have no idea why and I'm asking for help.
I'll give some general details here:
- ESP32 with CP2102
- having USB cable with data link
- Windows 10
- I have added the driver manually from the Action > Add legacy hardware because it wasn't (the driver) showing up in the first place
evans_picolo
Re: ESP32 port not being seen by computer although having Silicon Labs CP2102 Driver
Postby evans_picolo » Thu Mar 09, 2023 2:16 pm
Have you tested another USB cable? ESP32 seems to be very sensitive with poor quality cables.
Zenith Fall
Postby Zenith Fall » Thu Mar 09, 2023 3:37 pm
Thank you for taking your time to respond
Yes I have same issue. Tried with 3 cables and no result.
I think i should add this point as well.
- there was a uart to usb bridge controller under Other devices
- I uninstalled thinking the driver wasn't installer properly (this is a grave mistake i feel)
Zenith Fall
Postby Zenith Fall » Wed Mar 15, 2023 8:30 am
UPDATE
It seems the issue is actually with the cable
Do get a cable like this (url below) for the ESP to be working
https://robu.in/product/50-cm-micro-usb-cable/
Users browsing this forum: Google [Bot] and 5 guests
