Capacitive touch.
harshcht
Capacitive touch.
Postby harshcht » Thu Jul 06, 2017 6:50 am
I was trying out the capacitive touch of ESP-32 using arduino IDE. this is my code :
void setup()
  Serial.begin(115200);
  delay(1000); // give me time to bring up serial monitor
  Serial.println("ESP32 Touch Test");
void loop()
  Serial.println(touchRead(T0));  // get value using T0
  delay(1000);
(this is an example code in the library itself)
My question is what exactly does the touchRead() function return? It certainly does not work like a switch (as in MPR121) because as I press it with more intensity or use any other surface (metal) the value changes. what exactly is the function returning?
tele_player
Re: Capacitive touch.
Postby tele_player » Fri Jul 07, 2017 5:35 am
Reading a capacitive touch pin returns an analog value which varies with capacitance. To use it, compare that value to a threshold.
Note: they don't all return the same value when not being touched, so I'd use a few reads to calibrate the threshold value.
Fuzzyzilla
Postby Fuzzyzilla » Fri Jul 07, 2017 7:58 pm
As @tele_player said, this value varies with the capacitance of the touch pin. It will range from about 2~64, with lower numbers meaning, counter-intuitively, more capacitance. To make this work as a button, you could do something like
if(touchRead(T0)<15){//True if touched, false if not.
  Serial.println("T0 Touched!");
You should tune the threshold (15 in this example) depending on the circuit. For instance, a longer wire will end up making the end value lower, possibly false-triggering the output!
Users browsing this forum: ChatGPT-User, Qwantbot and 3 guests
