Enabling Wifi breaks SD Card ability to read
jeeper1974
Postby jeeper1974 » Thu Mar 16, 2023 7:23 am
ESP-IDF: 4.4.2
When I initialize the wifi and try to read from a SD card I get the following error.
diskio_sdmmc: sdmmc_read_blocks failed (257)
Without wifi it reads from the sdcard just fine.
The SD card will still initialize fine.
I (1274) SD_CARD: Initializing SD card
I (1278) SD_CARD: Using SDMMC peripheral
I (1283) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
Type: SDHC/SDXC
Speed: 20 MHz
And wifi works without any issues. It is only when I go to access the SD card that this error comes up. Anyone have an issues like this before?
Roger
Re: Enabling Wifi breaks SD Card ability to read
Postby Sprite » Fri Mar 17, 2023 12:53 am
Potentially a power supply issue; can your 3.3V line supply enough power to run both the ESP32 as well as the SD card?
jeeper1974
Postby jeeper1974 » Tue Mar 21, 2023 3:14 pm
The power supply is ok. I found today that I can stream data over wifi and save to the SD card over a non-secure HTTP connection. As soon as I switch to a secure HTTPS connection the SD card write fails.
My SD card is connected to GPIO2, GPIO4, GPIO12, GPIO13, and GPIO15.
Now these are also ADC2 pins and I read that wifi and ADC2 cannot be used together. It looks like they can be used if those pins are not configured for ADC mode. Is it possible that WiFi uses those ADC2 GPIO pins for HTTPS connections? I don't know why that would be, but I can write to the SD card without a SSL connection, and cannot with a SSL connection.
felixcollins
Postby felixcollins » Thu Mar 23, 2023 9:19 pm
Are you using pure IDF or are you using ADF as well? What board are you using?
gudbrand
Postby gudbrand » Fri Jan 10, 2025 9:45 am
I have the same problem.
With WiFi running, SD_MMC readings is working with small files but with larger files (or after a while with smaller)
I get the error message "E (634939) diskio_sdmmc: sdmmc_read_blocks failed (257)"
When WiFi disabled, SD_MMC works fine.
This is consistent behavior.
Reading from Internal Flash-disc is fine with wifi running, same for ram-disc
I use Arduino with PlatformIO.
Regards.
MicroController
Postby MicroController » Fri Jan 10, 2025 11:29 am
Memory leak maybe.
Users browsing this forum: ChatGPT-User, PerplexityBot and 1 guest
