I2S to internal DAC with APLL make noises.
VladimirG
Postby VladimirG » Thu Mar 23, 2023 9:52 am
Hi.
I try to generate sine via I2S and internal DAC but i have some isues with it.
If i use APLL clock for I2S it make me possible to gen my signals but i got glitches.Hi.
pll_2d_clc is useles, i cannot configure I2S rate to get my sine freq.
My sine is 1kHz and 2kHz and sample rate 16kHz
First i tryed IDF v4, now v5.0.1.
Board is ESP32-wroom-32d
Is it hardware issue?
Code: Untitled.cpp Select all
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include <assert.h>
#include <freertos/FreeRTOS.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "driver/gpio.h"
#include "driver/i2s_std.h"
#include "driver/adc.h"
#include "driver/dac.h"
#include "driver/timer.h"
#include "esp_log.h"
#include "proj_dac.h"
#include "ring_buffer.h"
#include <hal/dac_ll.h>
#include <hal/adc_ll.h>
#include <hal/i2s_ll.h>
#include "esp_intr_alloc.h"
static const char *TAG = "wave_gen";
static QueueHandle_t i2s_queue;
static const int i2s_num = 0; // i2s port number
#define SND_RATE 16000
#define DAC_SND_RATE 1000
static uint8_t buff[2048];
static uint8_t btest[] = {
0, 95,0,95, 0, 93,0,86, 0, 86,0,63, 0, 75,0,41, 0, 63,0,31,
0, 51,0,41, 0, 41,0,63, 0, 34,0,86, 0, 31,0,95, 0, 34,0,86,
0, 41,0,63, 0, 51,0,41, 0, 63,0,31, 0, 75,0,41, 0, 86,0,63,
0, 93,0,86
};// 2 sine (1k & 2k)
void
dac_init(void)
static bool inited = false;
static i2s_chan_handle_t i2s_rx_h;
static i2s_chan_handle_t i2s_tx_h;
static i2s_chan_config_t i2s_chan_conf = {
.auto_clear = false,
.id = i2s_num,
.role = I2S_ROLE_MASTER,
.dma_desc_num = 2,
.dma_frame_num = 16
static i2s_std_config_t i2s_conf = {
.clk_cfg = {
.sample_rate_hz = DAC_SND_RATE,
.clk_src = I2S_CLK_SRC_APLL,
// .clk_src = I2S_CLK_SRC_DEFAULT,
.mclk_multiple = I2S_MCLK_MULTIPLE_512
.slot_cfg = {
.data_bit_width = I2S_SLOT_BIT_WIDTH_16BIT,
.slot_bit_width = I2S_SLOT_BIT_WIDTH_16BIT,
.slot_mode = I2S_SLOT_MODE_STEREO,
.slot_mask = I2S_STD_SLOT_BOTH,
.bit_shift = false,
.ws_pol = true,
.ws_width = I2S_SLOT_BIT_WIDTH_16BIT,
.msb_right = false
.gpio_cfg = {
.bclk = I2S_GPIO_UNUSED,
.din = I2S_GPIO_UNUSED,
.dout = I2S_GPIO_UNUSED,
.mclk = I2S_GPIO_UNUSED,
.ws = I2S_GPIO_UNUSED,
.invert_flags = {
.bclk_inv = false,
.mclk_inv = false,
.ws_inv = true
if(!inited) {
ESP_ERROR_CHECK(i2s_new_channel(&i2s_chan_conf, &i2s_tx_h, &i2s_rx_h));
ESP_ERROR_CHECK(i2s_channel_init_std_mode(i2s_rx_h, &i2s_conf));
ESP_ERROR_CHECK(i2s_channel_init_std_mode(i2s_tx_h, &i2s_conf));
ESP_LOGI(TAG,"N:%d, B:%d, A:%d, M(rx):%d, M(tx):%d",
I2S0.clkm_conf.clkm_div_num,
I2S0.clkm_conf.clkm_div_b,
I2S0.clkm_conf.clkm_div_a,
I2S0.sample_rate_conf.rx_bck_div_num,
I2S0.sample_rate_conf.tx_bck_div_num
I2S0.conf2.lcd_en = 1; //TRM page 318 12.5.3 ADC/DAC mode
I2S0.conf.rx_short_sync = 0;
I2S0.conf.tx_short_sync = 0;
I2S0.conf.rx_msb_shift = 0;
I2S0.conf.tx_msb_shift = 0;
ESP_ERROR_CHECK(dac_output_enable(DAC_CHANNEL_1));
ESP_ERROR_CHECK(dac_output_enable(DAC_CHANNEL_2));
ESP_ERROR_CHECK(i2s_channel_enable(i2s_rx_h));
ESP_ERROR_CHECK(i2s_channel_enable(i2s_tx_h));
size_t b_writen = 0;
vTaskDelay(1000 / portTICK_RATE_MS);
i2s_channel_write(i2s_tx_h, btest, sizeof(btest) / sizeof(btest[0]), &b_writen, portMAX_DELAY);
// 1 sample for data buff uint8 [z,R,z,L]
ESP_ERROR_CHECK(dac_i2s_enable());
inited = true;
} else{
ESP_ERROR_CHECK(i2s_channel_disable(i2s_rx_h));
ESP_ERROR_CHECK(i2s_channel_disable(i2s_tx_h));
ESP_ERROR_CHECK(i2s_channel_reconfig_std_clock(i2s_rx_h, &i2s_conf.clk_cfg));
ESP_ERROR_CHECK(i2s_channel_reconfig_std_clock(i2s_tx_h, &i2s_conf.clk_cfg));
void
dac_single_init(void )
dac_init();
esp_log_level_set("I2S",ESP_LOG_ERROR);
corz.org
Contact:
Re: I2S to internal DAC with APLL make noises.
Postby corz.org » Fri Mar 24, 2023 11:46 am
Try using the DACs built-in cosine generator.
VladimirG
Postby VladimirG » Mon Mar 27, 2023 7:37 am
Finally i need complex signal, not just sine...
