https://shorturl.at/lEMUX
I have quiet a few sensors attached to GPIOs on the same board and I am using a buck supply set at 5V and the ground is set to common for both supplies (5V for sensors and 5V to power ESP32 Dev board) Both supplies are providing set voltage and enough wattage.
Code: Untitled.c Select all
I can use 3V3 pin if its an option.
Is it a Dev Board design flaw or am I doing something stupid ? My powersupply is very stable 5V and 1Amp, so power draw isnt a problem.
