Wrover-Kit V3 enable button
Postby rudi ;-) » Wed Jul 12, 2017 1:32 pm
hi guys
not sure but can someone test this
enable button (sw1) is without function.
usually the kit reboot on push and release.
not here on this
if push bootloader button (sw2) and press sw1
and release sw1 then bootloader mode is here
i wounder, is there a change in this in V3 ./. V2
Re: Wrover-Kit V3 enable button
Postby Sprite » Thu Jul 13, 2017 1:24 am
Can you tell me if the devboard is connected to a computer, and if so which OS and terminal app you use? It may be that one of the hardware handshake lines manages to inadvertantly disable that button.
Postby rudi ;-) » Sat Jul 15, 2017 9:24 am
have sean and read your post jeroen, i come back to this asap with edit or reply
cause want "protokoll" the steps detailed i did. best wishes rudi ;-)
Users browsing this forum: Applebot, Bytespider, Qwantbot and 2 guests
