I want to configure the flash encryption on ESP32-C3 with OTA as Access Point, but I have problems with the encryption part.
Tehnically, I want to generate a pre-encrypted file of the firmware.
I have wrote the encryption key in the BLOCK_KEY0 (BLOCK4) with this command:
espefuse.py -p COM35 burn_key BLOCK_KEY0 cryptkey.bin XTS_AES_128_KEY --no-write-protect --no-read-protectCode: Select all
espsecure.py encrypt_flash_data --aes_xts --keyfile .\cryptkey.bin --output cryptedflash.bin .\build\throughput_client_demo.bin --address 0x20000 Code: Select all
idf.py build | idf.py -p COM35 flash
idf.py build | idf.py -p COM35 encrypted-app-flash
idf.py build | idf.py -p COM35 encrypted-flash
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0x9 (SPI_FAST_FLASH_BOOT)
Saved PC:0x403cfa8a
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd5988,len:0x2ae4
load:0x403cc710,len:0x948
load:0x403ce710,len:0x487c
entry 0x403cc710
I (25) boot: ESP-IDF v5.0.1-dirty 2nd stage bootloader
I (25) boot: compile time 15:05:24
I (25) boot: chip revision: v0.4
I (27) boot.esp32c3: SPI Speed : 80MHz
I (32) boot.esp32c3: SPI Mode : DIO
I (37) boot.esp32c3: SPI Flash Size : 4MB
I (42) boot: Enabling RNG early entropy source...
I (47) boot: Partition Table:
I (51) boot: ## Label Usage Type ST Offset Length
I (58) boot: 0 nvs WiFi data 01 02 00009000 00005000
I (65) boot: 1 otadata OTA data 01 00 0000e000 00002000
I (73) boot: 2 phy_init RF data 01 01 00011000 00001000
I (80) boot: 3 ota_0 OTA app 00 10 00020000 0015e000
I (88) boot: 4 ota_1 OTA app 00 11 00180000 0015e000
I (95) boot: End of partition table
I (99) esp_image: segment 0: paddr=00020020 vaddr=3c100020 size=3a578h (238968) map
I (144) esp_image: segment 1: paddr=0005a5a0 vaddr=3fc92e00 size=02c9ch ( 11420) load
I (146) esp_image: segment 2: paddr=0005d244 vaddr=40380000 size=02dd4h ( 11732) load
I (152) esp_image: segment 3: paddr=00060020 vaddr=42000020 size=fad18h (1027352) map
I (312) esp_image: segment 4: paddr=0015ad40 vaddr=40382dd4 size=0ffc8h ( 65480) load
I (330) boot: Loaded app from partition at offset 0x20000
I (330) boot: Checking flash encryption...
E (330) flash_encrypt: Flash Encryption cannot be enabled (CRYPT_CNT (0) is write protected)
E (339) boot: OTA app partition slot 0 is not bootable
E (345) esp_image: image at 0x180000 has invalid magic byte (nothing flashed here?)
E (353) boot: OTA app partition slot 1 is not bootable
E (359) boot: No bootable app partitions in the partition tableCode: Select all
PS E:\Software\Espressif\frameworks\esp-idf-v5.0.1\examples\_projects\RGB_BLE_ESP32> espefuse.py -p COM35 summary
espefuse.py v4.5
Connecting...
Detecting chip type... ESP32-C3
=== Run "summary" command ===
EFUSE_NAME (Block) Description = [Meaningful Value] [Readable/Writeable] (Hex Value)
Calibration fuses:
TEMP_SENSOR_CAL (BLOCK2) Temperature calibration = 16.1 R/W (0b010100001)
ADC1_MODE0_D2 (BLOCK2) ADC1 calibration 1 = 148 R/W (0x25)
ADC1_MODE1_D2 (BLOCK2) ADC1 calibration 2 = 360 R/W (0x5a)
ADC1_MODE2_D2 (BLOCK2) ADC1 calibration 3 = -48 R/W (0x8c)
ADC1_MODE3_D2 (BLOCK2) ADC1 calibration 4 = 288 R/W (0x48)
ADC2_MODE0_D2 (BLOCK2) ADC2 calibration 5 = -456 R/W (0xf2)
ADC2_MODE1_D2 (BLOCK2) ADC2 calibration 6 = 232 R/W (0x3a)
ADC2_MODE2_D2 (BLOCK2) ADC2 calibration 7 = 388 R/W (0x61)
ADC2_MODE3_D2 (BLOCK2) ADC2 calibration 8 = 40 R/W (0x0a)
ADC1_MODE0_D1 (BLOCK2) ADC1 calibration 9 = 20 R/W (0b000101)
ADC1_MODE1_D1 (BLOCK2) ADC1 calibration 10 = -32 R/W (0b101000)
ADC1_MODE2_D1 (BLOCK2) ADC1 calibration 11 = 48 R/W (0b001100)
ADC1_MODE3_D1 (BLOCK2) ADC1 calibration 12 = 8 R/W (0b000010)
ADC2_MODE0_D1 (BLOCK2) ADC2 calibration 13 = 0 R/W (0b000000)
ADC2_MODE1_D1 (BLOCK2) ADC2 calibration 14 = 0 R/W (0b000000)
ADC2_MODE2_D1 (BLOCK2) ADC2 calibration 15 = 0 R/W (0b000000)
ADC2_MODE3_D1 (BLOCK2) ADC2 calibration 16 = 0 R/W (0b000000)
Config fuses:
DIS_ICACHE (BLOCK0) Disables ICache = False R/W (0b0)
DIS_DOWNLOAD_ICACHE (BLOCK0) Disables Icache when SoC is in Download mode = False R/W (0b0)
DIS_FORCE_DOWNLOAD (BLOCK0) Disables forcing chip into Download mode = False R/W (0b0)
DIS_CAN (BLOCK0) Disables the TWAI Controller hardware = False R/W (0b0)
VDD_SPI_AS_GPIO (BLOCK0) Set this bit to vdd spi pin function as gpio = False R/W (0b0)
BTLC_GPIO_ENABLE (BLOCK0) Enable btlc gpio = 0 R/W (0b00)
POWERGLITCH_EN (BLOCK0) Set this bit to enable power glitch function = False R/W (0b0)
POWER_GLITCH_DSENSE (BLOCK0) Sample delay configuration of power glitch = 0 R/W (0b00)
DIS_DIRECT_BOOT (BLOCK0) Disables direct boot mode = False R/W (0b0)
DIS_USB_SERIAL_JTAG_ROM_PRINT (BLOCK0) Disables USB-Serial-JTAG ROM printing = False R/W (0b0)
UART_PRINT_CONTROL (BLOCK0) Sets the default UART boot message output mode = Enabled R/W (0b00)
FORCE_SEND_RESUME (BLOCK0) Force ROM code to send a resume command during SPI = False R/W (0b0)
bootduring SPI boot
ERR_RST_ENABLE (BLOCK0) Use BLOCK0 to check error record registers = with check R/W (0b1)
DISABLE_WAFER_VERSION_MAJOR (BLOCK0) Disables check of wafer version major = False R/W (0b0)
DISABLE_BLK_VERSION_MAJOR (BLOCK0) Disables check of blk version major = False R/W (0b0)
BLOCK_USR_DATA (BLOCK3) User data
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
Efuse fuses:
WR_DIS (BLOCK0) Disables programming of individual eFuses = 272 R/W (0x00000110)
RD_DIS (BLOCK0) Disables software reading from BLOCK4-10 = 0 R/W (0b0000000)
Flash Config fuses:
FLASH_TPUW (BLOCK0) Configures flash startup delay after SoC power-up, = 0 R/W (0x0)
unit is (ms/2). When the value is 15, delay is 7.
5 ms
Identity fuses:
SECURE_VERSION (BLOCK0) Secure version (used by ESP-IDF anti-rollback feat = 0 R/W (0x0000)
ure)
MAC (BLOCK1) Factory MAC Address
= a0:76:4e:b2:31:20 (OK) R/W
WAFER_VERSION_MINOR_LO (BLOCK1) WAFER_VERSION_MINOR least significant bits = 4 R/W (0b100)
PKG_VERSION (BLOCK1) Package version = 0 R/W (0b000)
BLK_VERSION_MINOR (BLOCK1) BLOCK version minor = 2 R/W (0b010)
WAFER_VERSION_MINOR_HI (BLOCK1) WAFER_VERSION_MINOR most significant bits = 0 R/W (0b0)
WAFER_VERSION_MAJOR (BLOCK1) WAFER_VERSION_MAJOR = 0 R/W (0b00)
OPTIONAL_UNIQUE_ID (BLOCK2) Optional unique 128-bit ID
= ca 34 17 62 ab d3 75 3e 6c cc b6 78 99 6d 8d 8a R/W
BLK_VERSION_MAJOR (BLOCK2) BLOCK version major = With calibration R/W (0b01)
CUSTOM_MAC (BLOCK3) Custom MAC Address
= 00:00:00:00:00:00 (OK) R/W
WAFER_VERSION_MINOR (BLOCK0) calc WAFER VERSION MINOR = WAFER_VERSION_MINOR_HI = 4 R/W (0x4)
<< 3 + WAFER_VERSION_MINOR_LO (read only)
Jtag Config fuses:
SOFT_DIS_JTAG (BLOCK0) Software disables JTAG. When software disabled, JT = 0 R/W (0b000)
AG can be activated temporarily by HMAC peripheral
DIS_PAD_JTAG (BLOCK0) Permanently disable JTAG access via pads. USB JTAG = False R/W (0b0)
is controlled separately.
Security fuses:
DIS_DOWNLOAD_MANUAL_ENCRYPT (BLOCK0) Disables flash encryption when in download boot mo = False R/W (0b0)
des
SPI_BOOT_CRYPT_CNT (BLOCK0) Enables encryption and decryption, when an SPI boo = Disable R/- (0b000)
t mode is set. Enabled when 1 or 3 bits are set,di
sabled otherwise
SECURE_BOOT_KEY_REVOKE0 (BLOCK0) If set, revokes use of secure boot key digest 0 = False R/W (0b0)
SECURE_BOOT_KEY_REVOKE1 (BLOCK0) If set, revokes use of secure boot key digest 1 = False R/W (0b0)
SECURE_BOOT_KEY_REVOKE2 (BLOCK0) If set, revokes use of secure boot key digest 2 = False R/W (0b0)
KEY_PURPOSE_0 (BLOCK0) KEY0 purpose = XTS_AES_128_KEY R/- (0x4)
KEY_PURPOSE_1 (BLOCK0) KEY1 purpose = USER R/W (0x0)
KEY_PURPOSE_2 (BLOCK0) KEY2 purpose = USER R/W (0x0)
KEY_PURPOSE_3 (BLOCK0) KEY3 purpose = USER R/W (0x0)
KEY_PURPOSE_4 (BLOCK0) KEY4 purpose = USER R/W (0x0)
KEY_PURPOSE_5 (BLOCK0) KEY5 purpose = USER R/W (0x0)
SECURE_BOOT_EN (BLOCK0) Enables secure boot = False R/W (0b0)
SECURE_BOOT_AGGRESSIVE_REVOKE (BLOCK0) Enables aggressive secure boot key revocation mode = False R/W (0b0)
DIS_DOWNLOAD_MODE (BLOCK0) Disables all Download boot modes = False R/W (0b0)
ENABLE_SECURITY_DOWNLOAD (BLOCK0) Enables secure UART download mode (read/write flas = False R/W (0b0)
h only)
BLOCK_KEY0 (BLOCK4)
Purpose: XTS_AES_128_KEY
Encryption key0 or user data
= 65 3a b9 80 26 df 99 31 98 2a 30 4f 71 18 7c a7 64 0b 33 db c3 a3 61 1f 3d 9d 80 ef 56 cb 15 25 R/W
BLOCK_KEY1 (BLOCK5)
Purpose: USER
Encryption key1 or user data
BLOCK_KEY2 (BLOCK6)
Purpose: USER
Encryption key2 or user data
BLOCK_KEY3 (BLOCK7)
Purpose: USER
Encryption key3 or user data
BLOCK_KEY4 (BLOCK8)
Purpose: USER
Encryption key4 or user data
BLOCK_KEY5 (BLOCK9)
Purpose: USER
Encryption key5 or user data
BLOCK_SYS_DATA2 (BLOCK10) System data (part 2)
Spi_Pad_Config fuses:
SPI_PAD_CONFIG_CLK (BLOCK1) SPI CLK pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_Q (BLOCK1) SPI Q (D1) pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_D (BLOCK1) SPI D (D0) pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_CS (BLOCK1) SPI CS pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_HD (BLOCK1) SPI HD (D3) pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_WP (BLOCK1) SPI WP (D2) pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_DQS (BLOCK1) SPI DQS pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_D4 (BLOCK1) SPI D4 pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_D5 (BLOCK1) SPI D5 pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_D6 (BLOCK1) SPI D6 pad = 0 R/W (0b000000)
SPI_PAD_CONFIG_D7 (BLOCK1) SPI D7 pad = 0 R/W (0b000000)
Usb Config fuses:
DIS_USB_JTAG (BLOCK0) Disables USB JTAG. JTAG access via pads is control = False R/W (0b0)
led separately
DIS_USB_DEVICE (BLOCK0) Disables USB DEVICE = False R/W (0b0)
USB_EXCHG_PINS (BLOCK0) Exchanges USB D+ and D- pins = False R/W (0b0)
DIS_USB_SERIAL_JTAG_DOWNLOAD_MODE (BLOCK0) Disables USB-Serial-JTAG download feature in UART = False R/W (0b0)
download boot mode
Wdt Config fuses:
WDT_DELAY_SEL (BLOCK0) Selects RTC WDT timeout threshold at startup = False R/W (0b0)Thanks in advance.
