Non-static member function as callback for espconn_regist_connectcb
alex323qp
Postby alex323qp » Fri Jul 14, 2017 6:37 am
Hi guys, I'm new to the ESP32 world and just started working with the NONOS-SDK.
I'm writing my own libraries in c++ and got stuck trying to define the callbacks for a few network events. I've been trying to find ways around it but no luck so far.
Normally in C you would do:
void onConnected(void *args){...}
void connect(){
	struct espconn *conn = (struct espconn *) os_zalloc(sizeof(struct espconn));
	espconn_regist_connectcb(conn, (espconn_connect_callback) onConnected);
But since my callback is a member function I'm obviously getting a compilation error (error: converting from 'void (FooClass::*)(void*)' to 'espconn_connect_callback {aka void (*)(void*)}')
Is there any c++ expert out there that could throw some light on this? I basically need the following (or similar) to work:
void FooClass::onConnected(void *args){...}
void FooClass::connect(){
Any help would be greatly appreciated!
A.
Re: Non-static member function as callback for espconn_regist_connectcb
Postby Sprite » Fri Jul 14, 2017 2:13 pm
Erm... are you sure you didn't accidentally grab one of the ESP8266 SDKs? They are not compatible with the ESP32. The ESP32 only has ESP-IDF as an SDK.
alex323qp
Postby alex323qp » Sat Jul 15, 2017 12:05 am
oh dear... sorry guys, wrong forum... I even wrote 'new to the ESP32 world..', I guess no more coffees late at night for me.
Cheers!
A.
martinayotte
Postby martinayotte » Sun Jul 16, 2017 3:17 pm
( strange thing here : I've posted an answer here yesterday, and today, my post has been deleted ... :evil: )
( Ok ! I find why : it was deleted, but posted on esp8266 forum, where OP posted the same question there_
Because of the nature of C++ object, the signature of non-static method isn't the same as the signature of plain C callback, this is due to the fact that non-static method require a "this" as argument. Therefore the compiler error ...
To workaround this, the method needs to be static. But this method will not be able to access object data member, except if a global pointer is kept as a singleton.
https://stackoverflow.com/questions/240 ... d-in-class
alex323qp
Postby alex323qp » Mon Jul 17, 2017 12:17 am
Hi @martinayotte, @ESP_Sprite made me realize this wasn't the right place for this question, so I re-posted it on a different forum. I think you replied there. Thanks heaps for your help, I'll investigate and let you know :-D.
A.
Users browsing this forum: Baidu [Spider], PetalBot and 3 guests
