gpio: gpio_set_level(226): GPIO output gpio_num error
PI12EMSE
Postby PI12EMSE » Fri Jun 02, 2023 9:21 am
I have a problem concerning the writing of the pins. I want to put them to 1 to drive a Multiplexers (MUXO & MUXI in the code below) but when i try to control MUXI, i have the error code in the Serial terminal "E (X) gpio: gpio_set_level(226): GPIO output gpio_num error" and i don't know why there is this problem neither how to fix it.
Code: Source.cpp Select all
#include "MUX.h"
//Define Utilisateur
#define DEBUG 1
#define i 16
#define j 16
//Define connection pins on ESP32
#define S0_MUXO 2
#define S1_MUXO 15
#define S2_MUXO 14
#define S3_MUXO 18
#define SIG_MUXO 33
#define EN_MUXO 27
#define S0_MUXI 35
#define S1_MUXI 34
#define S2_MUXI 3
#define S3_MUXI 1
#define SIG_MUXI 32
#define EN_MUXI 21
int a = 0;
int b = 0;
int c = 0;
MUX muxi = MUX(S0_MUXI, S1_MUXI, S2_MUXI, S3_MUXI, SIG_MUXI, EN_MUXI, MUXI);
MUX muxo = MUX(S0_MUXO, S1_MUXO, S2_MUXO, S3_MUXO, SIG_MUXO, EN_MUXO, MUXO);
void setup() {
Serial.begin(115200);
muxo.enable();
muxi.enable();
void loop() {
//CODE PRINCIPALE
while (a < j) {
muxi.choix_channel(a);
muxi.ON();
while (b < i) {
muxo.choix_channel(b);
c = a + b;
b++;
b = 0;
a++;
a = 0;
if (DEBUG) {
Serial.println("End loop");
Code: MUX.cpp Select all
#include "esp32-hal-gpio.h"
#include "MUX.h"
MUX::MUX(int S0, int S1, int S2, int S3, int SIG, int EN, TYPE _type) {
pin_S0 = S0;
pin_S1 = S1;
pin_S2 = S2;
pin_S3 = S3;
pin_EN = EN;
pin_SIG = SIG;
type = _type;
pinMode(pin_EN, OUTPUT);
digitalWrite(pin_EN, LOW);
pinMode(pin_S0, OUTPUT);
pinMode(pin_S1, OUTPUT);
pinMode(pin_S2, OUTPUT);
pinMode(pin_S3, OUTPUT);
digitalWrite(pin_S0, LOW);
digitalWrite(pin_S1, LOW);
digitalWrite(pin_S2, LOW);
digitalWrite(pin_S3, LOW);
if (type == MUXO) {
pinMode(pin_SIG, INPUT_PULLDOWN);
if (type == MUXI) {
pinMode(pin_SIG, OUTPUT);
void MUX::disable() {
digitalWrite(pin_EN, HIGH);
void MUX::enable() {
void MUX::ON() {
if (type == MUXI) {
digitalWrite(pin_SIG, HIGH);
void MUX::OFF() {
if (type == MUXI) {
digitalWrite(pin_SIG, LOW);
void MUX::choix_channel(int ch) {
if (ch & 0b0001) {
digitalWrite(pin_S0, HIGH);
if (ch & 0b0010) {
digitalWrite(pin_S1, HIGH);
if (ch & 0b0100) {
digitalWrite(pin_S2, HIGH);
if (ch & 0b1000) {
digitalWrite(pin_S3, HIGH);
MUX::~MUX() {
true == true;
Code: Untitled.cpp Select all
#pragma once
#ifndef MUX_h
#define MUX_h
#include "Arduino.h"
enum TYPE { MUXO, MUXI };
class MUX {
public:
int pin_S0;
int pin_S1;
int pin_S2;
int pin_S3;
int pin_EN;
int pin_SIG;
TYPE type;
MUX(int S0, int S1, int S2, int S3, int EN, int SIG, TYPE _type);
~MUX();
void choix_channel(int ch);
void enable();
void disable();
void ON();
void OFF();
#endif
Thanks for your help
lbernstone
Re: gpio: gpio_set_level(226): GPIO output gpio_num error
Postby lbernstone » Sat Jun 03, 2023 6:11 pm
I didn't really look at your code, but pins 34&35 are input only.
Users browsing this forum: ChatGPT-User, Google [Bot], PerplexityBot and 6 guests
