Bluetooth connection lost after pairing
chucrut
Postby chucrut » Thu Jun 15, 2023 3:36 pm
I'm trying to run the Classic Bluetooth "acceptor" example:
https://github.com/espressif/esp-idf/tr ... p_acceptor
With the same sdkconfig configuration settings as the example
I turn on the bluetooth in the phone. I select the ESP32 device.
Then pop up a window with the pairing number:
At the same time this windows pops up, in the terminal i receive the following message:
W (162921) BT_HCI: hcif conn complete: hdl 0x80, st 0x0
W (162940) BT_HCI: hcif link supv_to changed: hdl 0x80, supv_to 8000
As soon as I pair the devices in the phone, the authentication is succesfull, but i receive the following message in the terminal:
W (245220) BT_HCI: hci cmd send: disconnect: hdl 0x80, rsn:0x13
W (245296) BT_HCI: hcif disc complete: hdl 0x80, rsn 0x16
And the connection process stops there. The connection proccess cannot complete
The serial port callback never reach the state: ESP_SPP_SRV_OPEN_EVT (SPP Server connection open)
I think i had this same issue months ago. I think was related with HCI. Now i have a fresh installation, with the latest ESP-IDF version. ESP-IDF works fine. VSCode works fine.
I tried to search the error code rsn:13, but i cannot find any information.
I think is related with the supervision timeout for the HCI link. Where can i change this value?
chucrut
Re: Bluetooth connection lost after pairing
Postby chucrut » Fri Jun 16, 2023 7:28 pm
chucrut
Postby chucrut » Fri Jun 16, 2023 7:40 pm
I tried with this configuration:
chucrut
And also tried with HCI instead of PCM
chucrut
Postby chucrut » Fri Jun 16, 2023 9:19 pm
I tested both ESP32 WROOM 32 and ESP32 PICO MINI 02 and their behaviour is slightly different
ESP32 WROOM 32 not even pair
ESP32 PICO MINI 02 pair and disconnect, like the pictures above
InfiniteArray
Postby InfiniteArray » Fri Jun 14, 2024 6:18 am
Hi chucrut! Almost one year later I'm dealing with exactly the same issue with an ESP32-WROOM-32E and a Quest 3. I have created this post before finding yours: https://esp32.com/viewtopic.php?f=19&t=40345
One thing I found is that it may be related to the type of connection. The bt_spp_acceptor uses the Serial Port Profile from the Bluetooth spec. When I tried the a2dp_sink example, which uses the Advanced Audio Distribution Profile, the connection wasn't terminated.
Interestingly though, the bt_spp_acceptor example works with my phone. Have you been able to get to the bottom of this at all or gain any additional insights into this problem?
InfiniteArray
Postby InfiniteArray » Sat Jun 15, 2024 6:20 pm
Hey chucrut,
The connection being closed after pairing is normal for SPP. You should still be able to access the paired device later in your application.
Users browsing this forum: Applebot, ChatGPT-User, meta-externalagent and 7 guests
