ESP32 PSRAM support
Re: ESP32 PSRAM support
Postby rudi ;-) » Mon Jul 10, 2017 9:58 am
Good to hear you found the problem. So you have the Lyontek chip working as well now?
will get this lyontek wild horse this week,
btw please check jeroen ( FYI )
txs!
Postby rudi ;-) » Wed Jul 12, 2017 12:06 am
interesting, PSRAM & FLASH same QIO CLK time + frequency, why not share on 40MHz?
Because of SPI Read ID function only with 4 / 8 MHz ?
I think we can on custom mode the Read ID save and share the CLK in 40 MHz - would save a GPIO ( IO17 )
Postby rudi ;-) » Wed Jul 12, 2017 1:06 am
flash clk comes 2 clks earlier -
_ psram clk need a cycl after #CE goes high for terminated_
Postby rudi ;-) » Mon Jul 17, 2017 7:08 pm
Hi
few weeks ago i got an email, that there is a guy, that have request samples
from a PSRAM manufacturer and if there comes samples, then he will share
if they send more as one :)
it was a long time cause one time the trader has shipped on wrong address and not to the guy.
so the manufacturer must send again to the trader for forwarding to the guy.
after this was done the guy send me again an email, that he get samples 3 peaces
and he will share to me one peaces ( how cool is that ? he got only 3 and he share to me from this one peaces - )
Today i got a parcel from switzerland and the guy did what he promissed.
i got today the long long waiting PSRAM in 3.3V and 64Mbit from Lyontek
it is the 64er L ( 3.3 ) version not S ( 1.8 ) version
so now, what i can do for the guy and you folks and me :)
i can test this on a Rev0 and Rev1 Silicon SoC ESP32.
First start was simple, does the 3.3V Version passes the ID Check.
This was done - and the ID Check passed successful
Then the next step was, to test this on a Rev1 and ... why not - i taked the Wrover-Kit where DOOM was run with 1.8V Flash and 1.8V ESP-PSRAM32 .
So i remove first the Case of wrover and saw, that the SoC was 112017 ( mmh ) and is still Rev1 ( mmh )
the next i remove the 1.8V ESP-PSRAM32 and the 1.8V Flash.
Then i solder the 3.3V PSRAM 64Mbit Version and a 3.3V Flash from a Wroom32 :)
the MTDI ( IO12 ) was then pulled down ( GND )
cause there is 10K Ohm in the pulled up bootstrap line ( R9 )
checked then the fine 3.3V that comes from VDD_SDIO intern regulator
After this steps i flashed the DOOM Firmware and....
... it work's!
sum:
q2222ch
Postby q2222ch » Mon Jul 17, 2017 7:38 pm
@rudi;-)
WiFive
Postby WiFive » Mon Jul 17, 2017 10:17 pm
Stable, no crash? Try for 80mhz?
You have another wrover-kit to measure difference in power consumption?
Postby rudi ;-) » Mon Jul 17, 2017 10:31 pm
is the KIT/esp-idf up2date for 80 Mhz and psram combine?
#yes will do a patch and test#
but earliest after wednesday :)
edit: forget to answere the top question:
yes - i think it is stable - but have to test more with it.
btw 1.8V
32, 64 ( 128 comes in August )
now MP also 256Mbit
yes can compare few things here now.
love express DHL :lol:
temp4eb
Postby temp4eb » Sun Jul 23, 2017 2:26 am
You can download the beta esp-idf and the toolchain from the usual spots (https://github.com/espressif/esp-idf and https://github.com/espressif/crosstool-NG) but be sure to switch to the psram-compatible branches. For esp-idf, the branch is called 'feature/psram_malloc', for the toolchain it is called 'xtensa-1.22.x-ext_ram_patch'. Note that there are no binaries available for the toolchain, you will need to build it from source. For the different OSses, this is documented here: Linux Mac (Sorry, no Windows support for this yet.). Note: In order to get the psram version, in the instructions at the 'git clone' command, replace 'xtensa-1.22.x' with 'xtensa-1.22.x-ext_ram_patch'. For esp-idf, just clone esp-idf as usual, then do 'git checkout feature/psram_malloc'.
after you have do 'git checkout feature/psram_malloc'
be sure you do this step then :
git submodul update --init
-> toolchain successful
esp8266@esp8266-VirtualBox:~/esp32psram/xtensa-esp32-elf/bin$ xtensa-esp32-elf-gcc --version
xtensa-esp32-elf-gcc (crosstool-NG crosstool-ng-1.22.0-64-g47d56eb) 5.2.0
Copyright (C) 2015 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-> esp-idf successful
-> hello_world successful
wrover modul still revision 0
can we check on Rev0 wrover the pSRAM?
edit:
tested -
--- ok - no pointer --
/*spiram*/
#include "esp_heap_alloc_caps.h"
// #include "../spiram.h" /*** void enable_spi_sram(); ***/
uint32_t* buffer = pvPortMallocCaps(4*1024*1024, MALLOC_CAP_SPISRAM);
    if (buffer==NULL) {
       printf("could not create SPIRAM Pointer\n");
    } else {
      printf("RAM init done\n");
Hi Rudi,
I got a piece of ESP32 WROVER KIT V3 board which had the ESP-WROVER with 4MB of psRAM.And I had git clone the feature/psram_malloc branch esf-idf code.The build failed when I open the ext PSRAM features.It seems need special xtensa-esp32-elf files .Since I use the Win7 64bit ,so I take the Msys2 as the IDE,which need xtensa-esp32-elf-XX.exe to build the firmware.I tried to make and build xtensa-1.22.x-ext_ram_patch version crosstool-ng but failed.I noticed you were using the win7 too.Could you please send me the xtensa-esp32-elf-XX.exe which could build the psram ESP32 code?Or Could you please tell me how to get the xtensa-esp32-elf-XX.exe which could build the psram ESP32 code?Thanx!
Postby rudi ;-) » Sun Jul 23, 2017 2:57 am
Hi Rudi,
Thanx!
hi temp4eb
there is just in time officially no windows (*.exe) support for the feature/psram_malloc
you need to build the toolchain under linux and there you can then compile the code.
an other way is, you build the toolchain with posix and cygwin under windows
then you get the *.exe like you wrote.
see my attached log, this runs pretty fine - until last steps - debuger tools, then there is missing something
( have not look deeper just in time - but the next days i will try again )
perhabs ivan/jeroen can look into too - perhabs they see what is missing in the last steps.
its really the final step :) -- 99.99 prozent was done :) but i think there is a missing step ..
it was a fast try - but will try again slower next days
build.log
cygwin posix try build
(14.91 MiB) Downloaded 1618 times
edit:
shortly last steps:
[ALL ] Making init.c
[ALL ] i686-build_pc-cygwin-gcc -g -O2 -I. -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/common -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/config -DLOCALEDIR=""/home/esp-psram/crosstool-NG/builds/xtensa-esp32-elf/share/locale"" -DHAVE_CONFIG_H -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../include/opcode -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../opcodes/.. -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../readline/.. -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../zlib -I../bfd -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../bfd -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../include -I../libdecnumber -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/../libdecnumber -I/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/gnulib/import -Ibuild-gnulib/import -DTUI=1 -I/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools/include -I/usr/include/python2.7 -I/usr/include/python2.7 -Wall -Wpointer-arith -Wno-unused -Wunused-value -Wunused-function -Wno-switch -Wno-char-subscripts -Wempty-body -Wpointer-sign -Wmissing-prototypes -Wdeclaration-after-statement -Wmissing-parameter-type -Wold-style-declaration -Wold-style-definition -Wformat-nonliteral -c -o init.o -MT init.o -MMD -MP -MF .deps/init.Tpo init.c
[ALL ] rm -f gdb.exe
[ALL ] i686-build_pc-cygwin-gcc -g -O2 -static-libstdc++ -static-libgcc -Wl,--stack,12582912 -o gdb.exe gdb.o xtensa-tdep.o xtensa-config.o solib-svr4.o ser-base.o ser-unix.o ser-pipe.o ser-tcp.o remote.o dcache.o tracepoint.o ax-general.o ax-gdb.o remote-fileio.o remote-notif.o ctf.o tracefile.o tracefile-tfile.o cli-dump.o cli-decode.o cli-script.o cli-cmds.o cli-setshow.o cli-logging.o cli-interp.o cli-utils.o mi-out.o mi-console.o mi-cmds.o mi-cmd-catch.o mi-cmd-env.o mi-cmd-var.o mi-cmd-break.o mi-cmd-stack.o mi-cmd-file.o mi-cmd-disas.o mi-symbol-cmds.o mi-cmd-target.o mi-cmd-info.o mi-interp.o mi-main.o mi-parse.o mi-getopt.o tui-command.o tui-data.o tui-disasm.o tui-file.o tui-hooks.o tui-interp.o tui-io.o tui-layout.o tui-out.o tui-regs.o tui-source.o tui-stack.o tui-win.o tui-windata.o tui-wingeneral.o tui-winsource.o tui.o python.o py-arch.o py-auto-load.o py-block.o py-bpevent.o py-breakpoint.o py-cmd.o py-continueevent.o py-xmethods.o py-event.o py-evtregistry.o py-evts.o py-exitedevent.o py-finishbreakpoint.o py-frame.o py-framefilter.o py-function.o py-gdb-readline.o py-inferior.o py-infevents.o py-infthread.o py-lazy-string.o py-linetable.o py-newobjfileevent.o py-objfile.o py-param.o py-prettyprint.o py-progspace.o py-signalevent.o py-stopevent.o py-symbol.o py-symtab.o py-threadevent.o py-type.o py-unwind.o py-utils.o py-value.o py-varobj.o guile.o elfread.o stap-probe.o dtrace-probe.o posix-hdep.o posix-strerror.o c-exp.o cp-name-parser.o ada-exp.o jv-exp.o d-exp.o f-exp.o go-exp.o m2-exp.o p-exp.o version.o annotate.o addrmap.o auto-load.o auxv.o agent.o bfd-target.o blockframe.o breakpoint.o break-catch-sig.o break-catch-throw.o break-catch-syscall.o findvar.o regcache.o cleanups.o charset.o continuations.o corelow.o disasm.o dummy-frame.o dfp.o source.o value.o eval.o valops.o valarith.o valprint.o printcmd.o block.o symtab.o psymtab.o symfile.o symfile-debug.o symmisc.o linespec.o dictionary.o infcall.o infcmd.o infrun.o expprint.o environ.o stack.o thread.o exceptions.o extension.o filesystem.o filestuff.o inf-child.o interps.o minidebug.o main.o macrotab.o macrocmd.o macroexp.o macroscope.o mi-common.o event-loop.o event-top.o inf-loop.o completer.o gdbarch.o arch-utils.o gdbtypes.o gdb_bfd.o gdb_obstack.o osabi.o copying.o memattr.o mem-break.o target.o target-dcache.o parse.o language.o build-id.o buildsym.o findcmd.o std-regs.o signals.o exec.o reverse.o bcache.o objfiles.o observer.o minsyms.o maint.o demangle.o dbxread.o coffread.o coff-pe-read.o dwarf2read.o mipsread.o stabsread.o corefile.o dwarf2expr.o dwarf2loc.o dwarf2-frame.o dwarf2-frame-tailcall.o ada-lang.o c-lang.o d-lang.o f-lang.o objc-lang.o ada-tasks.o ada-varobj.o c-varobj.o ui-out.o cli-out.o varobj.o vec.o go-lang.o go-valprint.o go-typeprint.o jv-lang.o jv-valprint.o jv-typeprint.o jv-varobj.o m2-lang.o opencl-lang.o p-lang.o p-typeprint.o p-valprint.o sentinel-frame.o complaints.o typeprint.o ada-typeprint.o c-typeprint.o f-typeprint.o m2-typeprint.o ada-valprint.o c-valprint.o cp-valprint.o d-valprint.o f-valprint.o m2-valprint.o serial.o mdebugread.o top.o utils.o ui-file.o user-regs.o frame.o frame-unwind.o doublest.o frame-base.o inline-frame.o gnu-v2-abi.o gnu-v3-abi.o cp-abi.o cp-support.o cp-namespace.o reggroups.o trad-frame.o tramp-frame.o solib.o solib-target.o prologue-value.o memory-map.o memrange.o xml-support.o xml-syscall.o xml-utils.o target-descriptions.o target-memory.o xml-tdesc.o xml-builtin.o inferior.o osdata.o gdb_usleep.o record.o record-full.o gcore.o gdb_vecs.o jit.o progspace.o skip.o probe.o common-utils.o buffer.o ptid.o gdb-dlfcn.o common-agent.o format.o registry.o btrace.o record-btrace.o waitstatus.o print-utils.o rsp-low.o errors.o common-debug.o debug.o common-exceptions.o btrace-common.o fileio.o compile.o compile-c-symbols.o compile-c-types.o compile-object-load.o compile-object-run.o compile-loc2c.o compile-c-support.o inflow.o init.o ../readline/libreadline.a ../opcodes/libopcodes.a ../bfd/libbfd.a -L./../zlib -lz ../libiberty/libiberty.a ../libdecnumber/libdecnumber.a -lncurses -lm -liconv -ldl -lpython2.7 /home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools/lib/libexpat.a ../libiberty/libiberty.a -luser32 build-gnulib/import/libgnu.a
[ALL ] tui-win.o: In function `tui_update_variables':
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:301: undefined reference to `acs_map'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:310: undefined reference to `acs_map'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:307: undefined reference to `acs_map'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:304: undefined reference to `acs_map'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:297: undefined reference to `acs_map'
[ALL ] tui-win.o:/home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:313: more undefined references to `acs_map' follow
[ALL ] tui-win.o: In function `tui_refresh_all_win':
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:698: undefined reference to `curscr'
[ALL ] tui-win.o: In function `tui_resize_all':
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:780: undefined reference to `stdscr'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:781: undefined reference to `curscr'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui-win.c:782: undefined reference to `stdscr'
[ALL ] tui.o: In function `tui_enable':
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui.c:437: undefined reference to `stdscr'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui.c:460: undefined reference to `LINES'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui.c:461: undefined reference to `COLS'
[ALL ] /home/esp-psram/crosstool-NG/.build/src/gdb-7.10/gdb/tui/tui.c:476: undefined reference to `stdscr'
[ERROR] collect2: error: ld returned 1 exit status
[ALL ] Makefile:1390: recipe for target 'gdb.exe' failed
[ERROR] make[3]: *** [gdb.exe] Error 1
[ALL ] make[3]: Leaving directory '/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/build/build-gdb-cross/gdb'
[ALL ] Makefile:8758: recipe for target 'all-gdb' failed
[ERROR] make[2]: *** [all-gdb] Error 2
[ALL ] make[2]: Leaving directory '/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/build/build-gdb-cross'
[ALL ] Makefile:848: recipe for target 'all' failed
[ERROR] make[1]: *** [all] Error 2
[ALL ] make[1]: Leaving directory '/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/build/build-gdb-cross'
[ERROR]
[ERROR] >>
[ERROR] >> Build failed in step 'Installing cross-gdb'
[ERROR] >> called in step '(top-level)'
[ERROR] >>
[ERROR] >> Error happened in: CT_DoExecLog[scripts/functions@257]
[ERROR] >> called from: do_debug_gdb_build[scripts/build/debug/300-gdb.sh@120]
[ERROR] >> called from: do_debug[scripts/build/debug.sh@35]
[ERROR] >> called from: main[scripts/crosstool-NG.sh@646]
[ERROR] >>
[ERROR] >> For more info on this error, look at the file: 'build.log'
[ERROR] >> There is a list of known issues, some with workarounds, in:
[ERROR] >> 'docs/B - Known issues.txt'
[ERROR]
[ERROR] (elapsed: 133:44.83)
$ ./xtensa-esp32-elf-gcc.exe -v
Using built-in specs.
COLLECT_GCC=./xtensa-esp32-elf-gcc
COLLECT_LTO_WRAPPER=/home/esp-psram/crosstool-NG/builds/xtensa-esp32-elf/libexec/gcc/xtensa-esp32-elf/5.2.0/lto-wrapper.exe
Target: xtensa-esp32-elf
Configured with: /home/esp-psram/crosstool-NG/.build/src/gcc-5.2.0/configure --build=i686-build_pc-cygwin --host=i686-build_pc-cygwin --target=xtensa-esp32-elf --prefix=/home/esp-psram/crosstool-NG/builds/xtensa-esp32-elf --with-local-prefix=/home/esp-psram/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf/sysroot --with-sysroot=/home/esp-psram/crosstool-NG/builds/xtensa-esp32-elf/xtensa-esp32-elf/sysroot --with-newlib --enable-threads=no --disable-shared --with-pkgversion='crosstool-NG crosstool-ng-1.22.0-64-g47d56eb' --disable-__cxa_atexit --enable-cxx-flags='-fno-exceptions -fno-rtti' --with-gmp=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-mpfr=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-mpc=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-isl=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-cloog=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --with-libelf=/home/esp-psram/crosstool-NG/.build/xtensa-esp32-elf/buildtools --enable-lto --enable-target-optspace --without-long-double-128 --disable-libgomp --disable-libmudflap --disable-libssp --disable-libquadmath --disable-libquadmath-support --disable-nls --disable-multilib --enable-languages=c,c++ --disable-libstdcxx-verbose
Thread model: single
gcc version 5.2.0 (crosstool-NG crosstool-ng-1.22.0-64-g47d56eb)
it is not 100 prozent finished -
so just in time - you must build the toolchain under linux.
(I am unfortunately for 1 1/2 weeks (summer flu)
Can not be as I would like.)
if the cygwin build is 100 prozent successful then i will upload the toolchain -
and write the steps in windows for build it with cygwin ( posix )
hope this helps?!
temp4eb
Postby temp4eb » Sun Jul 23, 2017 3:34 am
Hi Rudi,
Thanx!
hi temp4eb
build.log
hope this helps?!
Hi Rudi,
Thanx for your reply!Looking forward to your exe files when you are available and I will take another try according to your suggestion right now.Many thanx!
Users browsing this forum: Baidu [Spider], ChatGPT-User, Semrush [Bot] and 6 guests
