I have a doubt, in the ESP serial flasher protocol.h do the commands have a reason for having those precise values? If so, where can I consult that in the technical reference manual? And if not why does it skip certain values?
typedef enum __attribute__((packed))
FLASH_BEGIN = 0x02,
FLASH_DATA = 0x03,
FLASH_END = 0x04,
MEM_BEGIN = 0x05,
MEM_END = 0x06,
MEM_DATA = 0x07,
SYNC = 0x08,
WRITE_REG = 0x09,
READ_REG = 0x0a,
SPI_SET_PARAMS = 0x0b,
SPI_ATTACH = 0x0d,
CHANGE_BAUDRATE = 0x0f,
FLASH_DEFL_BEGIN = 0x10,
FLASH_DEFL_DATA = 0x11,
FLASH_DEFL_END = 0x12,
SPI_FLASH_MD5 = 0x13,
} command_t;
Thank you
ESP SERIAL FLASHER SPI COMMAND
Re: ESP SERIAL FLASHER SPI COMMAND
They're communication parameters with the ROM baked into the ESP chips; the ROM checks for those numbers and does the thing that goes with it. Skipped numbers probably used to be there at some time but were removed without shifting the other numbers up. I don't think it's documented in any hardware docs, as ROM-defined behaviour kinda-sortta is seen as software.
Thank you, I have another question I'm looking up the SPI register in the technical reference manual and I can't find the flash ID register. Do you know where is it?
Users browsing this forum: Google [Bot] and 7 guests
