debuging Korvo-2 using eclipse
mfawzy79
Postby mfawzy79 » Sun Jul 02, 2023 8:53 pm
I used to debug my ESP32-S2 on NodeMCU using PlatformIO debgugger and there was one port for downloading and monitoring. now I bought Korvo-2 v3 and it has only one port for downloading/debugging.
I have many questions:
1- how can I see the logs during the debuging process, as we have only one port?
2- when I tried to debug using eclipse i got the following error
Open On-Chip Debugger v0.11.0-esp32-20221026 (2022-10-26-14:48)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
Flashing C:/Espressif/esp-adf/examples/display/lcd_camera/build/bootloader/bootloader.bin at 0x0
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description '*', serial '*' at bus location '*'
Error: unable to open ftdi device with vid 0403, pid 6014, description '*', serial '*' at bus location '*'
** OpenOCD init failed **
shutdown command invoked
** Flashing Failed **
-1
Started by GNU MCU Eclipse
I'm assmming this error because I didn't install the USB using Zadig but I'm getting the same error even after installing the driver
Please advise how can I debug ?
