I am new to ESP-IDF and wanted to make a custom outbox implementation for the MQTT client.
I have imported the file as suggested and this is in my main CMakeLists file
idf_component_get_property(mqtt mqtt COMPONENT_LIB)
set_property(TARGET ${mqtt} PROPERTY SOURCES ${CMAKE_CURRENT_LIST_DIR}/path/custom_outbox.c APPEND)
I tried using
idf_component_set_property(mqtt REQUIRES nvs_flash APPEND )Adding nvs_flash to REQUIRES for esp-mqtt component directly in the idf directory works though, I don't know why appending it through CMake instead doesn't work. I would have assumed it does the same thing.
Any help appreciated. I am using ESP-IDF on vscode.
