Seeed XIAO ESP32C3 only runs programm when connected to PC
Julie_xxx
Postby Julie_xxx » Thu Jul 13, 2023 10:53 am
Hello :smiley:
I am using two ESP32C3 and both only run the programm when I connect them to my PC. When I use the 3,3V Input via a normal power supply the program does not start.
And when I’ve disconnected the board for a long time it is not enough to only connect it again. I have to upload the same code again to make it run. Both boards show this behavior. Any advice?
Re: Seeed XIAO ESP32C3 only runs programm when connected to PC
Postby Sprite » Fri Jul 14, 2023 4:56 am
Does it work when you press the RST button after you apply power?
Julie_xxx
Postby Julie_xxx » Mon Jul 17, 2023 1:05 pm
Hi, I could fix this issue. I was using 3,3V from a laboratory power supply, but becase the power loss was so huge I had to use 3,5V to make it run.
However...by now I have discovered a way bigger problem: When I upload my code the programm starts running and everything works fine. But when I cut off power for a short moment and put it on again(externally or PC), the code does not get executed anymore. I have to plug power off and on again many times to make it work. Pressing Restart does not change anything. Unconnecting the USB-C, pressing Boot, reconnecting the USB and letting the Boot button go afterwards does help, but there must be a way to fix this problem. It would be extremly unreliable if you have to restart the board like this every time afer power got cut off. (also it has nothing to do with the code, the same behavior showed while making a LED blink)
Maybe I have to put a capacitor somewere? Has anyone had this problem as well? I did not find much about it on the internet.
Postby Sprite » Tue Jul 18, 2023 1:18 am
That is an odd issue; pressing RESET ought to clear all issues. There's nothing else connected to the board I assume?
bidrohini
Postby bidrohini » Tue Jul 18, 2023 8:40 am
You can also port your question to the seedstudio forum: https://forum.seeedstudio.com/
Franco
Postby Franco » Tue Jul 18, 2023 10:16 am
Could it be related to the LDO or other power management circuitry hasn't output discharge feature? Just trying to guess.
MicroController
Postby MicroController » Tue Jul 18, 2023 6:57 pm
Was thinking about the same. I can't find any documentation saying that the XIAO can be powered via its 3v3 pin at all...
LDOs can behave weirdly when fed voltage from their output side w/o input voltage.
derekg
Postby derekg » Sat Aug 05, 2023 1:20 am
I'm having nearly the same issue. My program only runs when connected to my macbook via USB-C. If I connect it to an external USB-C power supply, it doesn't work. I just received 3 from AliExpress a few days ago and haven't tried powering via pins yet.
Did you also by chance order from AliExpress? I'm wondering if maybe they're counterfeit.
derekg
Postby derekg » Sat Aug 05, 2023 3:34 am
Do you do the following after Serial.begin() ?:
while (!Serial);
Remove it.
racecarparts
Postby racecarparts » Wed Nov 22, 2023 12:26 am
^^ That saved me! Thank you!
Users browsing this forum: Bytespider and 5 guests
