Hi all - I'm finding it a bit tricky to communicate with a camera lens motor through my ESP32-S3 using serial communication. I'm using the Freenove ESP32-S3 WROOM.
The camera lens motor has a cable with a USB-A male connector and an FT232RL chipset. Connection parameters are ASCII protocol, 115200 baud, 8-N-1. The motor expects ASCII Modbus messages and it doesn't provide any confirmation messages (on receipt, or on connection, etc.) so I can't tell if it is connected successfully.
If I connect the motor cable directly to my computer's USB port I can send messages successfully to the motor and control it.
I've tried the Arduino ESP32-S3 "USBSerial" sketch that outputs messages on connect, disconnect, and will echo what is sent from the USB UART port on the USB OTG port. This works when I connect both the USB UART and the USB OTG to my computer - the messages from USB UART are being shown on USB OTG and I'm getting "CDC CONNECTED" and "CDC DISCONNECTED" messages.
However, when I connect my ESP32-S3 with a cable from the USB OTG port to my camera lens motor (as shown in the picture) USB connector, I'm not getting a "CDC CONNECTED" message. I've tried sending a message through to the motor but it's not responding (and without confirmation messages I can't tell if it's connected successfully).
I'm open to using the pins on the device rather than the USB OTG connector if that would be simpler.
I have attached a screenshot of the connections I currently have.
If anyone has any ideas on what I'm missing and can help, it would be appreciated!
Device:
https://github.com/Freenove/Freenove_ES ... ROOM_Board
ESP32-S3 communicating with Camera Lens Motor that has a FT232RL USB connector
- 2023-06-19 ESP32 Communication.png (209.2 KiB) Viewed 2695 times
Re: ESP32-S3 communicating with Camera Lens Motor that has a FT232RL USB connector
You're trying to connect two USB devices together; that doesn't really work. It would work if you could configure the S3 USB port as a host, but I don't think Arduino has support for that yet. Better to skip the FT232 entirely and connect the serial wires to an ESP32 UART.
Thanks for the reply... No wonder I was struggling! I'll look to connect cables directly without the FT232RL in the way.
Much appreciated for the swift response!
Thank you, it worked when I connected the RX, TX, GND wires from the motor cable directly to the pins on my ESP32.
Appreciated!
Appreciated!
Good to hear you got it to work!
Users browsing this forum: ChatGPT-User and 5 guests
