Your antenna doesn't have a resonance-frequency anymore.
I have an even higher directivity and almost hit the 2.4GHz:
You can find the STLs and the Python-scripts in the attachment.
I cannot be, that's why I called the method a 'razor' and not 'proof'. It tells me that unless there's a very good explanation (and that does not include any theoretical-only one), it's probably not worth spending time on.How can You be sure, without giving it a try?
The last results you posted? If those results are correct, your antenna only had a S11 of -12dB, which as an antenna is a pretty shit rating. Given the fact that the mPIFA is known to perform better than the results you got, I think the more likely explanation is that the simulation gave bogus results for some reason.My design has a 100% better result in OpenEMS.
Users browsing this forum: Google [Bot], Qwantbot and 1 guest
