Web Server minimal with Mesh Ap
rsimpsonbusa
Postby rsimpsonbusa » Wed Aug 02, 2023 9:29 pm
Hi all.
It would be great if one could have a minimal webserver in any mesh node (Ap of course). I did install a small one but I cannot access it since the SSID and Password are hidden, no matter that when printing the network config AP section we get a AP name of ESPM_XXXX where XXX has part of the MAC address of the ESP32. But NO password and the one set for MESH_AP_PASSWORD does not work.
In my case each node is a controls Hardware that may be different for each individual node and I need to configure it or get diagnostics from that node but not via the Root due to comms limitations.
Any suggestions.
nopnop2002
Contact:
Re: Web Server minimal with Mesh Ap
Postby nopnop2002 » Sun Mar 30, 2025 1:43 pm
You cannot start an HTTP server on a leaf node.
You can only start an HTTP server on the root node.
This is because all nodes in the MESH-NETWORK have the same IP address.
MQTT is effective when communicating with individual nodes.
MQTT allows communication with specific nodes within a Mesh-Network.
