INPUT_PULLUP on GPIO18 & GPIO19 pins
ogedik
Postby ogedik » Fri Aug 11, 2023 3:58 pm
I am using USB CDC on ESP-C3-13 module and connecting to my notebook via USB interface. When I push boot button my notebook is able to see COM port and able to download program successfully into module. After I reset module USB connection drops normally, but Windows create a notification with an "USB Device Not Recognized" error. While figuring out the problem I found out that I set GPIO18 andGPIO19 pins to INPUT_PULLUP. After I remark those lines USB device is able to find by notebook.
pinMode(18, INPUT_PULLUP);
pinMode(19, INPUT_PULLUP);
This situation is same for Serial.* commands too.
Is it not permitted to set GPIO18 and 19 to INPUT_PULLUP while using USB CDC scenario? And why I am facing same situation when I use Serial?
Thank you.
Orkun Gedik
ogedik
Re: INPUT_PULLUP on GPIO18 & GPIO19 pins
Postby ogedik » Fri Aug 11, 2023 6:29 pm
UPDATE:
No problem with Serial. Problem only on GPIO18 and GPIO19
alecamaracm
Postby alecamaracm » Sat Aug 12, 2023 2:20 am
GPIOs 18 and 19 are the ones the USB peripherals use.
If you use pinMode on them, you are basically making them behave as normal GPIOs, therefore losing the USB functionality.
ogedik
Postby ogedik » Tue Aug 15, 2023 4:52 pm
Thank you for your reply, alecamaracm. I will take this into account.
Best regards,
Orkun Gedik
Users browsing this forum: Amazon [Bot], ChatGPT-User, PetalBot and 3 guests
