How to configure the Rainmaker ESP32 to use a static IP?
mottibz
Postby mottibz » Fri Aug 18, 2023 8:57 am
Is there a way to provision the ESP32 when first configuring Rainmaker, to use a Static IP?
This is very important for me.
Thanks!
Piyush
Re: How to configure the Rainmaker ESP32 to use a static IP?
Postby Piyush » Mon Aug 21, 2023 4:32 pm
Moved this topic under ESP IDF since RainMaker uses ESP IDF's wifi provisioning. As of now, it can accept only ssid, passphrase, bssid and channel. There is no provision to set static IP.
mottibz
Postby mottibz » Mon Aug 21, 2023 6:12 pm
Hi, can you provide the link to the other forum so that I can follow the discusson there? Thanks!
Users browsing this forum: ChatGPT-User, Google [Bot], Qwantbot and 3 guests
