ESP32-H2-MINI minimal required schematic to flash and run?
mremre
Postby mremre » Wed Aug 23, 2023 6:13 pm
I'm trying to flash and run the ESP32-H2-MINI module with minimum schematic, but there is no connection with module.
My schematic has following pin connections:
1(GND) - GND
3(3V3) - 3.3V
8(EN) - through 10k to 3.3V
22(IO8) - through 10k to 3.3V
23(IO9) - GND
30(RXD0) - FTDI TX
31(TXD0) - FTDI RX
Running > "idf.py erase-flash" returns "No serial ports found"
What do I miss. Maybe all the module's ground pins 1, 2, 11, 14, 36~53 must be connected?
mremre
Re: ESP32-H2-MINI minimal required schematic to flash and run?
Postby mremre » Sat Aug 26, 2023 8:22 pm
Fixed!
As the module is really microscopic, I made a mistake and soldered wire meant for pin 8(EN) to pin 9(IO0).
After soldering it to pin 8(EN) communication started and I could flash the module.
Thank you for your attention.
Postby Sprite » Sun Aug 27, 2023 3:12 am
Good to see you solved this, thanks for indicating it was a soldering and not a design issue.
