No toolchain file found error
Vineethad
Postby Vineethad » Wed Aug 23, 2023 10:14 am
Hello ,
I am currently working with ESPRESSIF IDE version-5.0.2. While I am building project for ESP32_C3 board the IDE is working fine. But when I am building project for ESP32_C6 board it is showing error like below attached file.
Please find me the solution.
Screenshot 2023-08-23 153842.png (153.75 KiB) Viewed 3569 times
frhr
Re: No toolchain file found error
Postby frhr » Wed Aug 23, 2023 12:59 pm
I think esp-idf v5.0 does not support esp32c6. The supported SoC for different esp-idf releases can be found here https://github.com/espressif/esp-idf#es ... patibility. I guess you can try to update to v5.1.
HTH
Vineethad
Postby Vineethad » Thu Aug 24, 2023 10:15 am
I have downloaded the ESP-IDF version 5.1.1 tool .But I couldn't find the ESP32-C6 module name in ESP-Target .
I mentioned the related file below.
Screenshot 2023-08-24 154203.png (163.86 KiB) Viewed 3455 times
frhr
Postby frhr » Thu Aug 24, 2023 10:43 am
it seems that the support was added in eclipse plugin v2.10.0. From the screenshot it looks like you are using eclipse plugin v2.9.1. Maybe you can try to follow the "How to get the latest version?" at https://github.com/espressif/idf-eclips ... ag/v2.10.0
HTH
Vineethad
Postby Vineethad » Fri Aug 25, 2023 12:23 pm
I have added the eclipse plugin v2.10.0. But while building the project, I am getting the cmake errors . I have attached the related file below.
Thank you.
ESP-IDF product information.png (211.26 KiB) Viewed 3325 times
frhr
Postby frhr » Fri Aug 25, 2023 5:05 pm
the selected toolchain and target do not match as reported in the error message. I guess maybe the plugin takes the target from the stale sdkconfig, but it's hard say. Anyway the cmake command is obviously wrong. -DCMAKE_TOOLCHAIN_FILE refers to eps32c6, but -DIDF_TARGET is set to esp32. You can try to delete the C:\Users\SigmaUser\Desktop\esp\hello_world\build directory and also C:\Users\SigmaUser\Desktop\esp\hello_world\sdkconfig. My best guess is that some old configuration(sdkconfig, CMakeCache.txt) from the previous target(esp32) is still present in your project. Deleting the build directory and sdkconfig should hopefully solve this.
HTH
