ESP32-C3 serial access via device links not working
joba-1
Postby joba-1 » Fri Sep 15, 2023 9:48 am
I currently evaluate an ESP32-C3 Super Mini board because of it's small form factor.
I noticed that on linux the device name of the usb serial port changes all the time (e.g. on every press of the reset button).
Since it is good practice anyways, I wanted to set up an udev rule to create an alias for the device with a fixed name.
For that I created a file /etc/udev/rules.d/98_c3mini.rules with this content:
SUBSYSTEMS=="usb", ATTRS{idVendor}=="303a", ATTRS{idProduct}=="1001", MODE:="0660", GROUP:="dialout", SYMLINK+="ttyUSB_c3mini"
This creates a link /dev/ttyUSB_c3mini every time I plug in the device.
/dev/ttyUSB_c3mini_1
Hardware ID: LINK=/dev/bus/usb/003/044 LINK=/dev/bus/usb/003/044
Description: n/a
Unfortunately this link does not work:
pio device monitor -p /dev/ttyUSB_c3mini -b 115200
UserSideException: Could not configure port: (25, 'Inappropriate ioctl for device')
Links of my other "traditional" ESP32 devices point directly to the device in /dev. Here this would be /dev/ttyACM1. But this link points to somewhere in /dev/bus/usb?
/dev/ttyACM1
Hardware ID: USB VID:PID=303A:1001 SER=48:31:B7:3E:6B:F4 LOCATION=3-9.1:1.0
Description: USB JTAG/serial debug unit
Any idea why this happens and how I can fix this?
dallim30
Re: ESP32-C3 serial access via device links not working
Postby dallim30 » Mon Mar 11, 2024 3:39 am
hi,
I’m currently experiencing the same issue.
I can't upload firmware to esp32-c3 super mini
pload_port = \\.\COM4 <-- Com Ports" in Device Manager in Windows 10 when in DFU mode
;upload_speed = 2000000
upload_speed = 115200
monitor_speed = 115200
Thanks in advance for any help you may have,
Chip is ESP32-C3 (revision v0.4)
Features: WiFi, BLE
Crystal is 40MHz
MAC: dc:da:0c:8e:ba:e0
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00003fff...
Flash will be erased from 0x00010000 to 0x000fafff...
Compressed 13216 bytes to 9529...
A fatal error occurred: Packet content transfer stopped (received 8 bytes)
*** [upload] Error 2
Users browsing this forum: Baidu [Spider], Google [Bot], PetalBot and 1 guest
