Guru Meditation Error: Core 1 panic'ed (StoreProhibited) (only crashes when function invoked from ISR)
RacerX10
Postby RacerX10 » Thu Sep 14, 2023 6:17 pm
When I call the function below from an ISR, I'm randomly getting
It might run fine for 30 seconds, or 10 minutes before I get the crash.
When I call it from loop(), it appears to work fine.
I need to call it from my ISR because I'm doing a median filter on some timing values from an external interrupt.
Backtrace info and function are below.
Thank you for any assistance you can offer !
Code: Untitled.txt Select all
Guru Meditation Error: Core  1 panic'ed (StoreProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x4008f748 PS : 0x00060e33 A0 : 0x8008ff32 A1 : 0x3ffb2610
A2 : 0x3ffb8014 A3 : 0x3ffb1408 A4 : 0x3ffc3514 A5 : 0x00060c23
A6 : 0x00060c20 A7 : 0x00000001 A8 : 0x00000014 A9 : 0x00000000
A10 : 0x3ffb8064 A11 : 0x00000018 A12 : 0xa5a5a5a5 A13 : 0xa5a5a5a5
A14 : 0x3ffb8014 A15 : 0xa5a5a5a4 SAR : 0x0000001a EXCCAUSE: 0x0000001d
EXCVADDR: 0xa5a5a5b1 LBEG : 0x40086f38 LEND : 0x40086f43 LCOUNT : 0x00000000
Backtrace: 0x4008f745:0x3ffb2610 0x4008ff2f:0x3ffb2630 0x400901a4:0x3ffb2650 0x40083d16:0x3ffb2670 0x40083d29:0x3ffb26a0 0x40083d56:0x3ffb26c0 0x4009055d:0x3ffb26e0 0x400d7127:0x3ffb2700 0x400d8401:0x3ffb2720 0x400d859a:0x3ffb2780 0x400d198a:0x3ffb27c0 0x400d2285:0x3ffb2800 0x400daf6d:0x3ffb2820
#0 0x4008f745:0x3ffb2610 in remove_free_block at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/heap/heap_tlsf.c:212
(inlined by) block_locate_free at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/heap/heap_tlsf.c:448
(inlined by) tlsf_malloc at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/heap/heap_tlsf.c:779
#1 0x4008ff2f:0x3ffb2630 in multi_heap_malloc_impl at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/heap/multi_heap.c:197
#2 0x400901a4:0x3ffb2650 in multi_heap_malloc at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/heap/multi_heap_poisoning.c:230
(inlined by) multi_heap_malloc at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/heap/multi_heap_poisoning.c:219
#3 0x40083d16:0x3ffb2670 in heap_caps_malloc_base at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/heap/heap_caps.c:154
(inlined by) heap_caps_malloc_base at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/heap/heap_caps.c:99
#4 0x40083d29:0x3ffb26a0 in heap_caps_malloc at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/heap/heap_caps.c:174
#5 0x40083d56:0x3ffb26c0 in heap_caps_malloc_default at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/heap/heap_caps.c:199
#6 0x4009055d:0x3ffb26e0 in malloc at /Users/ficeto/Desktop/ESP32/ESP32S2/esp-idf-public/components/newlib/heap.c:24
#7 0x400d7127:0x3ffb2700 in TFT_eSPI::loadMetrics() at .pio/libdeps/esp32dev_default_16MB/TFT_eSPI/Extensions/Smooth_font.cpp:173
#8 0x400d8401:0x3ffb2720 in TFT_eSPI::loadFont(String, bool) at .pio/libdeps/esp32dev_default_16MB/TFT_eSPI/Extensions/Smooth_font.cpp:144
#9 0x400d859a:0x3ffb2780 in TFT_eSPI::loadFont(unsigned char const*) at .pio/libdeps/esp32dev_default_16MB/TFT_eSPI/Extensions/Smooth_font.cpp:17
#10 0x400d198a:0x3ffb27c0 in readTach() at src/main.cpp:343
#11 0x400d2285:0x3ffb2800 in loop() at src/main.cpp:283
#12 0x400daf6d:0x3ffb2820 in loopTask(void*) at C:/Users/Dave/.platformio/packages/framework-arduinoespressif32/cores/esp32/main.cpp:50
Code: Untitled.c Select all
int IRAM_ATTR MedianFilter::in(const int & value)
// sort sizeMap
// small vaues on the left (-)
// larger values on the right (+)
boolean dataMoved = false;
const uint8_t rightEdge = medFilterWin - 1; // adjusted for zero indexed array
totalSum += value - data[oldestDataPoint]; // add new value and remove oldest value
data[oldestDataPoint] = value; // store new data in location of oldest data in ring buffer
// SORT LEFT (-) <======(n) (+)
if(locationMap[oldestDataPoint] > 0) // don't check left neighbours if at the extreme left
for(uint8_t i = locationMap[oldestDataPoint]; i > 0; i--) //index through left adjacent data
uint8_t n = i - 1; // neighbour location
if(data[oldestDataPoint] < data[sizeMap[n]]) // find insertion point, move old data into position
sizeMap[i] = sizeMap[n]; // move existing data right so the new data can go left
locationMap[sizeMap[n]]++;
sizeMap[n] = oldestDataPoint; // assign new data to neighbor position
locationMap[oldestDataPoint]--;
dataMoved = true;
else
break; // stop checking once a smaller value is found on the left
// SORT RIGHT (-) (n)======> (+)
if(!dataMoved && locationMap[oldestDataPoint] < rightEdge) // don't check right if at right border, or the data has already moved
for(int i = locationMap[oldestDataPoint]; i < rightEdge; i++) //index through left adjacent data
int n = i + 1; // neighbour location
if(data[oldestDataPoint] > data[sizeMap[n]]) // find insertion point, move old data into position
sizeMap[i] = sizeMap[n]; // move existing data left so the new data can go right
locationMap[sizeMap[n]]--;
locationMap[oldestDataPoint]++;
else
break; // stop checking once a smaller value is found on the right
oldestDataPoint++; // increment and wrap
if(oldestDataPoint == medFilterWin) oldestDataPoint = 0;
return data[sizeMap[medDataPointer]];
lbernstone
Re: Guru Meditation Error: Core 1 panic'ed (StoreProhibited) (only crashes when function invoked from ISR)
Postby lbernstone » Fri Sep 15, 2023 4:43 pm
Not enough info to make a good diagnosis. You are either trying to use psram for this allocation (which happens automatically on allocation >4K), or your isr is trying to access heap memory that is simply not available in the context.
The more appropriate way to handle this is to have the ISR drop the needed data into a queue, with a separate process to pull data from the queue, process it, and return the result where it is needed. This can either be triggered by a queue event, a suspended process which gets notified, or in your normal processing loop.
RacerX10
Postby RacerX10 » Sat Sep 16, 2023 7:54 pm
My ISR event frequency is around 1ms at the top end. My main loop isn't processing fast enough to service the array and pull out the median value at that rate. That's why I left it all in the ISR, because it's a critical task that has to be handled above all other operations.
I tried a different Median function (just a straight-c function) that I found; it seems to be behaving quite a bit better than the arduino-specific library that I was using here. The total processing time on the ISR is generally under 5us so I wasn't too worried about it all being in the ISR. I might be wrong on that, however. I am still getting the occasional div by zero crash, but that's a much easier problem to track down than arcane memory allocation issues :)
Thanks !
Users browsing this forum: ChatGPT-User, PerplexityBot and 2 guests
