I purchased a new ESP32-DevKitC-VE from Mouser a couple of days ago. I can't get it to work.
I updated the ESP32 libraries and have tried all of the ESP32 generic boards. Several of them seem to be talking to the Arduino environment as it indicates a successful upload. However, the ino file doesn't work. The only thing in the file is a Serial.println("Test") followed by a delay(1000). Then another Serial.println("End Test") followed by another delay(1000). Nothing displays on the serial monitor.
When I press the reset button on the board, the serial monitor displays this:
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13964
load:0x40080400,len:3600
entry 0x400805f0
What ESP32 board should be assigned to this dev kit? It has 8Mb of memory and I do set that when I select a board. Or is the board so new that there is not board file yet available for the Arduino environment?
ESP32-DevKitC-VE not working
Re: ESP32-DevKitC-VE not working
I used the Manage Libraries tool to upgrade the libraries. I used Boards Manager to upgrade the boards library. I upgraded the Arduino IDE to 2.2.1. I selected the board type as ESP32 Wrover Kit (all versions). I then programmed the board and it is working.
I was using Arduino IDE 1.8.57.0 which was rather old.
lbernstone
It looks like the device is working fine; the ESP32 Dev Module board should be adequate. Did you try any of the included examples (under the file menu)?
Yes, I tried a couple of the examples and they worked. I didn't try the examples until after I did the upgrades.
There is no LED onboard to blink. I connected a couple external resistors and LEDs to GPIO pins and added blink functions to my code. The LEDs blink so I am sure the board is working as it should.
Users browsing this forum: Bytespider, meta-externalagent and 3 guests
