[machinehum@whitebox pl02-fw.git]$ /usr/bin/python /home/machinehum/projects/pl02-fw/modules/hal/espressif/components/esptool_py/esptool/esptool.py -t --chip auto --port /dev/ttyUSB0 --baud 921600 --before default_reset --after hard_reset write_flash -u --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 /home/machinehum/projects/pl02-fw/pl02-fw.git/build/esp32/esp-idf/build/bootloader/bootloader.bin 0x8000 /home/machinehum/projects/pl02-fw/pl02-fw.git/build/esp32/esp-idf/build/partitions_singleapp.bin 0x10000 build/esp32/zephyr/zephyr.bin
esptool.py v4.5
Serial port /dev/ttyUSB0
Connecting...TRACE +0.000 command op=0x08 data len=36 wait_response=1 timeout=0.100 data=
0707122055555555 5555555555555555 | ... UUUUUUUUUUUU
5555555555555555 5555555555555555 | UUUUUUUUUUUUUUUU
55555555 | UUUU
TRACE +0.000 Write 46 bytes:
c000082400000000 0007071220555555 | ...$........ UUU
5555555555555555 5555555555c0 | UUUUUUUUUUUUU.
TRACE +0.100 No serial data received.
.TRACE +0.050 command op=0x08 data len=36 wait_response=1 timeout=0.100 data=
55555555 | UUUU
.TRACE +0.051 command op=0x08 data len=36 wait_response=1 timeout=0.100 data=
55555555 | UUUU
55555555 | UUUU
TRACE +0.003 Read 1 bytes: c0
TRACE +0.000 Read 31 bytes:
0108040012205555 00000000c0c00108 | ..... UU........
0400122055550000 0000c0c0010804 | ... UU.........
TRACE +0.000 Received full packet: 010804001220555500000000
TRACE +0.002 Read 1 bytes: 00
1220555500000000 c0c0010804001220 | . UU...........
555500000000c0c0 01080400122055 | UU........... U
TRACE +0.002 Read 1 bytes: 55
00000000c0c00108 0400122055550000 | ........... UU..
0000c0c001080400 12205555000000 | ......... UU...
TRACE +0.003 Read 1 bytes: 00
TRACE +0.000 Read 15 bytes: c0c0010804001220555500000000c0
Detecting chip type...TRACE +0.000 command op=0x14 data len=0 wait_response=1 timeout=3.000 data=
TRACE +0.000 Write 10 bytes: c00014000000000000c0
TRACE +0.004 Read 1 bytes: c0
0108040012205555 01050000c0c00108 | ..... UU........
0400122055550105 0000c0c0010804 | ... UU.........
TRACE +0.000 Received full packet: 010804001220555501050000
Unsupported detection protocol, switching and trying again...
Connecting...TRACE +0.170 command op=0x08 data len=36 wait_response=1 timeout=0.100 data=
55555555 | UUUU
55555555 | UUUU
55555555 | UUUU
0108040007122055 00000000c0c00108 | ...... U........
0400071220550000 0000c0c0010804 | .... U.........
TRACE +0.000 Received full packet: 010804000712205500000000
0712205500000000 c0c0010804000712 | .. U............
205500000000c0c0 01080400071220 | U............
00000000c0c00108 0400071220550000 | ............ U..
0000c0c001080400 07122055000000 | .......... U...
TRACE +0.000 Read 15 bytes: c0c0010804000712205500000000c0
Detecting chip type...TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=00100040
TRACE +0.000 Write 14 bytes: c0000a04000000000000100040c0
TRACE +0.005 Read 1 bytes: c0
TRACE +0.000 Read 13 bytes: 010a0400831df00000000000c0
TRACE +0.000 Received full packet: 010a0400831df00000000000
ESP32
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=0ca0f53f
TRACE +0.000 Write 14 bytes: c0000a0400000000000ca0f53fc0
TRACE +0.000 Read 13 bytes: 010a040000a2000000000000c0
TRACE +0.000 Received full packet: 010a040000a2000000000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=14a0f53f
TRACE +0.000 Write 14 bytes: c0000a04000000000014a0f53fc0
TRACE +0.000 Read 13 bytes: 010a04000000100000000000c0
TRACE +0.000 Received full packet: 010a04000000100000000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=7c60f63f
TRACE +0.000 Write 14 bytes: c0000a0400000000007c60f63fc0
TRACE +0.000 Read 13 bytes: 010a04000020049600000000c0
TRACE +0.000 Received full packet: 010a04000020049600000000
Chip is ESP32-D0WD-V3 (revision v3.0)
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=10a0f53f
TRACE +0.000 Write 14 bytes: c0000a04000000000010a0f53fc0
TRACE +0.000 Read 13 bytes: 010a04003112000000000000c0
TRACE +0.000 Received full packet: 010a04003112000000000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=18a0f53f
TRACE +0.000 Write 14 bytes: c0000a04000000000018a0f53fc0
TRACE +0.000 Read 13 bytes: 010a04000400000000000000c0
TRACE +0.000 Received full packet: 010a04000400000000000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=1400f43f
TRACE +0.000 Write 14 bytes: c0000a0400000000001400f43fc0
TRACE +0.000 Read 13 bytes: 010a04005f01000000000000c0
TRACE +0.000 Received full packet: 010a04005f01000000000000
Crystal is 40MHz
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=08a0f53f
TRACE +0.000 Write 14 bytes: c0000a04000000000008a0f53fc0
TRACE +0.000 Read 14 bytes: 010a040049dbdc450000000000c0
TRACE +0.000 Received full packet: 010a040049c0450000000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=04a0f53f
TRACE +0.000 Write 14 bytes: c0000a04000000000004a0f53fc0
TRACE +0.000 Read 13 bytes: 010a0400bc9dd6ef00000000c0
TRACE +0.000 Received full packet: 010a0400bc9dd6ef00000000
MAC: c0:49:ef:d6:9d:bc
Uploading stub...
TRACE +0.000 command op=0x05 data len=16 wait_response=1 timeout=3.000 data=580d0000010000000018000000e00b40
TRACE +0.000 Write 26 bytes:
c000051000000000 00580d0000010000 | .........X......
000018000000e00b 40c0 | ........@.
TRACE +0.006 Read 1 bytes: c0
TRACE +0.000 Read 13 bytes: 01050400bc9dd6ef00000000c0
TRACE +0.000 Received full packet: 01050400bc9dd6ef00000000
TRACE +0.000 command op=0x07 data len=3432 wait_response=1 timeout=3.000 data=
580d000000000000 0000000000000000 | X...............
0800f43f1c00f43f 0000f43f00c0fc3f | ...?...?...?...?
1000f43f36410021 faffc02000380241 | ...?6A.!... .8.A
f9ffc02000280420 20749ce206050000 | ... .(. t......
0041f5ff81f6ffc0 2000a8048808a0a0 | .A...... .......
74e008000b226602 e786f4ff21f1ffc0 | t...."f.....!...
200039021df00000 a0ebfd3f186bfd3f | .9........?.k.?
8480000040400000 58abfd3fa4ebfd3f | ....@@..X..?...?
364100b1f9ff20a0 74101120a5c70096 | 6A.... .t.. ....
1a0681f6ff92a101 9099119a98c02000 | .............. .
b80991f3ffa0a074 9a88c02000921800 | .......t... ....
9090f41bc9c0c0f4 c02000c258009a9b | ......... ..X...
c02000a24900c020 0092180081eaff90 | . ..I.. ........
90f48080f4879947 81e5ff92a1019099 | .......G........
119a98c02000c809 a1e5ffb1e3ff879c | .... ...........
17c601007ce8871a dec60800c0200089 | ....|........ ..
0ac02000b9094602 00c02000b90ac020 | .. ...F... ....
00890991d7ff9a88 0c09c02000925800 | ........... ..X.
1df00000f820f43f f830f43f36410091 | ..... .?.0.?6A..
fdffc02000880980 80245648ff91faff | ... .....$VH....
c020008809808024 5648ff1df0000000 | . .....$VH......
1020f43f0020f43f 0000000836410010 | . .?. .?....6A..
1120a5fcff21faff 0c08c02000826200 | . ...!..... ..b.
91faff81f8ffc020 00926800c0200098 | ....... ..h.. ..
085679ffc0200088 027cf28022302020 | .Vy.. ...|.."0
041df00000000040 364100101120e5fb | .......@6A... ..
ff166aff81ecff91 fbffc02000926800 | ..j........ ..h.
c0200098085679ff 1df000000cc0fc3f | . ...Vy........?
ffffff000420f43f 36410021fcff3842 | ..... .?6A.!..8B
16830610112065f8 ff16fa050cf80c04 | ..... e.........
37a80d9822809910 82a0019048834040 | 7...".......H.@@
7410112025faff10 112025f3ff88220c | t.. %.... %...".
1b40981190ab01cc 1480ab01b1edffb0 | .@..............
9910b1ecffc02000 926b0091ceffc020 | ...... ..k.....
00a26900c02000a8 09567aff1c090c1a | ..i.. ...Vz.....
409a839033c09a88 394289221df00000 | @...3...9B."....
2c920040364100a2 a0c081fdffe00800 | ,..@6A..........
1df0000036410082 a0c0ad02879211a2 | ....6A..........
a0db81f7ffe00800 a2a0dc4604000000 | ...........F....
0082a0db87920881 f2ffe00800a2a0dd | ................
81f0ffe008001df0 3641003a32c60200 | ........6A.:2...
00a202001b221011 20a5fbff3792f11d | .....".. ...7...
f00000007cda0540 d82e06409cda0540 | ....|..@...@...@
1cdb0540362121a2 d11081faffe00800 | ...@6!!.........
460b0000000c1440 4411404363cd04bd | F......@D.@Cc...
01ad0281f5ffe008 00a0a074fc5acd04 | ...........t.Z..
10b120a2d11081f1 ffe008004a224033 | .. .........J"@3
c05603fd22a20b10 22b020a220b2d110 | .V.."...". . ...
81ecffe00800ad02 1c0b101120a5f7ff | ............ ...
2d0386000022a063 1df00000fc670040 | -....".c.....g.@
d092004008680040 36412162a107c066 | ...@.h.@6A!b...f
111a6659062c0a62 d1100c0552661a81 | ..fY.,.b....Rf..
f7ffe008000c1840 881147b802464500 | .......@..G..FE.
ad0681d4ffe00800 8634000092a41d50 | .........4.....P
73c0e099111a9940 77638909cd07bd01 | s......@wc......
20a22081cdffe008 0092a41de099111a | . .............
99a0a07488098caa 0c088266167d0886 | ...t.......f.}..
1600000092a41de0 9911109980826900 | ..............i.
10112025eaffbd07 ad01101120a5edff | .. %........ ...
10112025e9ffcd07 10b12060a62081bb | .. %...... `. ..
ffe0080092a41de0 99111a9988097022 | ..............p"
8070558037b5b092 a107c099111a9998 | .pU.7...........
098075c097b70246 dcff86e6ff0c0882 | ..u....F........
466ca2a41b10aaa0 81caffe00800560a | Fl............V.
ffb2a20ba2066c10 bbb0101120a58f00 | ......l..... ...
f7ea12f6470fb2a2 0d10bbb07abba24b | ....G.......z..K
001b7786f1ff7ceb b79ac16647088226 | ..w...|....fG..&
1a37b80287b59c22 a20b1022b060b620 | .7....."...".`.
ad02819bffe00800 101120a5dfffad02 | .......... .....
1c0b10112025e3ff 101120a5deff2c0a | .... %.... ...,.
81b1ffe008001df0 0820f43f70e2fa3f | ......... .?p..?
48240640f0220640 366100101120e5ca | H$.@.".@6a... ..
ff10a12081fbffe0 08003d0a0c12fc2a | ... ......=....*
880192a200908810 8901101120a5cfff | ............ ...
91f2ffa0a201c020 00822900a08820c0 | ....... ..)... .
2000826900b22100 a1edff81eeffe008 | ..i..!.........
00a023831df00000 ff0f000036410081 | ..#.........6A..
3bff0c1992480030 9c41992891fbff39 | ;....H.0.A.(...9
1829383030b49a22 2a33303c410c0229 | .)800.."*30<A..)
58394810112025f8 ff2d0a8c1a22a0c5 | X9H.. %..-..."..
1df00000502d0640 364100412cff5834 | ....P-.@6A.A,.X4
5033631663045814 5a53505c41460100 | P3c.c.X.ZSP\AF..
10112065caff8844 a61804882487a5ef | .. e...D....$...
101120a5c2ff166a ffa814cd03bd0281 | .. ....j........
f1ffe00800a0a074 8c4a52a0c4526405 | .......t.JR..Rd.
58143a5559145834 3055c059341df000 | X.:UY.X40U.Y4...
00c0fc3f4f484149 a8ebfd3f70e00b40 | ...?OHAI...?p..@
14e00b400c00f43f 3840f43fffff0000 | ...@...?8@.?....
8c80000010400000 acebfd3fbcebfd3f | .....@.....?...?
04c0fc3f08c0fc3f 04ecfd3f1400f43f | ...?...?...?...?
f0ffff00a8ebfd3f 18ebfc3f24c0fc3f | .......?...?$..?
7c680040ec670040 588600406c2a0640 | |h.@.g.@X..@l*.@
38320640142c0640 cc2c06404c2c0640 | 82.@.,.@.,.@L,.@
34850040cc900040 782e064030ef0540 | 4..@...@x..@0..@
589200404c820040 36c10021deff0c0a | X..@L..@6..!....
22610842a00081ee ffe0080021d9ff31 | "a.B........!..1
daffc6000049024b 223732f810112065 | .....I.K"72... e
c3ff0c4ba2c12010 1120e5c6ff22a101 | ...K.. .. ..."..
10112025c2ff5191 fe9022112a2531cf | .. %..Q...".*%1.
ffb1cfffc0200059 022178fe0c0c0c5a | ..... .Y.!x....Z
32620081dcffe008 0031caff42a101c0 | 2b.......1..B...
200028032c0a4022 20c0200029038131 | .(.,.@" . .)..1
ffe0080081d5ffe0 080021c3ffc02000 | ..........!... .
2802ccba1cc33022 1022c2f80c1320a3 | (.....0".".... .
830c0b81ceffe008 00f1bcff0c1dc2a0 | ................
010c1be2a10040dd 1100cc1180bb01a2 | ......@.........
a00081c7ffe00800 21b6ff0c042a5521 | ........!....*U!
c3fe72d22bc02000 28051672ffc02000 | ..r.+. .(..r.. .
38050c12c0200049 052241102203010c | 8.... .I."A."...
2822411182510949 512692071c388712 | ("A..Q.IQ&...8..
1e06080022030382 0302802211802220 | ...."......".."
6642112823c02000 2802295146010000 | fB.(#. .(.)QF...
1c22225109101120 a5b3ff0c8ba2c110 | .""Q... ........
10112065b7ff8203 0322030280881120 | .. e.....".....
88202198ff2020f4 87b21ca2a0c01011 | . !.. .........
2025b2ffa2a0ee10 1120a5b1ff101120 | %....... .....
25b0ff86dbff0000 2203011c39273934 | %......."...9'94
f62218c6d4000000 22c22f202074f642 | ."......"./ t.B
709189ff9022a028 02a0020022c2fe20 | p....".(...."..
20741c1927b902c6 cb009184ff9022a0 | t..'.........".
2802a0020092c230 909074b659c906c6 | (......0..t.Y...
002c4a6d0422a0c0 a7180206c4004951 | .,Jm."........IQ
0c72ad04101120e5 aaffad0410112065 | .r.... ....... e
aaff101120e5a8ff 101120a5a8ff0c8b | .... ..... .....
a2c11022c2ff1011 20e5abff5622fd46 | ...".... ...V".F
29000c1256c82c82 610f817affe00800 | )...V.,.a..z....
88f1a02883c6ae00 2688040c12c6ac00 | ...(....&.......
9823683360892080 80b456d8fe99c110 | .#h3`. ...V.....
112065c7ff98c16a 299c2a06f7ff0000 | . e....j).*.....
a0ac41816dffe008 0056eafc62d6f060 | ..A.m....V..b..`
a2c0cc2606810000 a090f45619fe8604 | ...&.......V....
00a0a0f599c18165 ffe0080098c1569a | .......e......V.
fa9066c00c190099 1160a2c06739e106 | ..f......`..g9..
04000000a0ac4181 5cffe0080056aaf8 | ......A.\....V..
62d6f060a2c056a6 fec66f00006d0422 | b..`..V...o..m."
a0c0268802868d00 6d040c02c68b0000 | ..&.....m.......
0026b8f38661000c 1226b802068500b8 | .&...a...&......
33a823101120e5a1 ffa024830681000c | 3.#.. ....$.....
1c66b853884320ac 116d0422a0c287ba | .f.S.C ..m."....
02867e00b853a823 c9e1101120e5c0ff | ..~..S.#.... ...
c60b000c1c66b82f 884320ac116d0422 | .....f./.C ..m."
a0c287ba02867500 2833b853a8232068 | ......u.(3.S.# h
82c9e110112065be ff2134fe496222d2 | ..... e..!4.Ib".
2b6922c8e1a0c483 2d0c866900a12ffe | +i".....-..i../.
6d04b20a0022a0c6 163b1a982382c8f0 | m...."...;..#...
22a0c0879901285a 0c09a2a0ef460200 | ".....(Z.....F..
9ab3b20b181b99b0 aa308729f2820305 | .........0.)....
9203048088119088 209203066d040099 | ........ ...m...
1180992082030780 880190882080aac0 | ... ........ ...
82a0c1a028934655 008118fe6d04a208 | ....(.FU....m...
0022a0c6167a14a8 3822a0c856fa1328 | ."...z..8"..V..(
58a24800c64d001c 8a6d040c12a71802 | X.H..M...m......
c64a00f873e863d8 53c843b833a82381 | .J..s.c.S.C.3.#.
0cffe008006d0aa0 2483464400000c12 | .....m..$.FD....
264802463f00a823 bd048104ffe00800 | &H.F?..#........
061e0080b0346d04 22a0c0560b0f8064 | .....4m."..V...d
418bc37cfd460e00 a83cb9c1c9e1d9d1 | A..|.F...<......
8100ffe00800c8e1 b8c1282c981ca80c | ..........(,....
d2210d9092102602 0ec02000e22a0020 | .!....&... ..*.
2d30e02210209920 c02000990a1bbbc2 | -0.". . . ......
cc10673bc2c69bff 664802469aff6d04 | ..g;....fH.F..m.
22a0c00626000c12 26b80246210021dc | "...&...&..F!.!.
fe98538823990221 dbfe89022d04861c | ..S.#..!....-...
0061d7fe0c1bd806 82c8f0ad042d0480 | .a...........-..
2b93d0ab8320aa10 6d0422a0c656ea05 | +.... ..m."..V..
c1d1fe22a0c9e80c 873e5380f01422a0 | ...".....>S...".
c056af042d0a4602 002aa3a86a4b22a9 | .V..-.F..*..jK".
09ad0b20fec02a9d 8732ed169adf21c4 | ... ..*..2....!.
fef90c9902c67bff 0c1266881621c1fe | ......{...f..!..
880216280082a0c8 490221bdfe49020c | ...(....I.!..I..
128024836d044601 00006d0422a0ff20 | ..$.m.F...m."..
a074101120e579ff 60a0741011206579 | .t.. .y.`.t.. ey
ff101120e577ff56 a2be2203011c2827 | ... .w.V.."...('
381ef6320206f7fe 22c2fd2020740cf8 | 8..2....".. t..
27b80286f3fe81ac fe8022a02802a002 | '.........".(...
0082a0d287125282 a0d487127a06edfe | ......R.....z...
0000008833a2a271 c0aa11682389f181 | ....3..q...h#...
b0fee0080021a1fe 91a2fec020002802 | .....!...... .(.
88f1203435c02211 9022102023208022 | .. 45."..". # ."
82ad0460b2c281a7 fee00800a2a3e881 | ...`............
a4fee0080006dbfe 0000d853c843b833 | ...........S.C.3
a823101120257dff 46d6fe00b2030322 | .#.. %}.F......"
030280bb1120bb20 b2cbf0a2c3181011 | ..... . ........
206599ff46cffe00 220303820302618f | e..F...".....a.
fd80221198368022 2022c2f090226316 | .."..6." "..."c.
22b298169a92909c 4146020099c11011 | ".......AF......
206562ff98c1a846 a61a04a826a7a9eb | eb....F....&...
101120a55aff166a ffa816cd02b2c318 | .. .Z..j........
8186fee008008c3a 32a0c4395638162a | .......:2..9V8.*
33391638362023c0 2936c6b5fe820302 | 39.86 #.)6......
22c3183203030c1c 80331180332032c3 | "..2.....3..3 2.
f0062300816cfe91 1dfde8083971e099 | ..#..l......9q..
c0996198270c1a97 b3010c3a89f1a9d1 | ..a.'......:....
e9c1101120255bff a8d19163fee8c1a9 | .... %[....c....
01a162fedd09bd02 c2c11cf2c11899c1 | ..b.............
816bfee00800b827 cd0aa87188f1a0bb | .k.....'...q....
c0b927a033c0b808 aa22a86198c1aabb | ..'.3....".a....
dd040c1ab908c0da 8390bbc0d0e074cc | ..............t.
7dd2db80d0ae9316 6a01ad0989f199c1 | }.......j.......
c9e11011202589ff 88f198c1c8e19268 | .... %.........h
00614efd88368ca3 c09f31c099c0d629 | .aN..6....1....)
0056f8f5d6ac0031 49fd22a0c7295346 | .V.....1I."..)SF
00008c3c9c08c682 fe1688a06144fd22 | ...<........aD."
a0c82956467ffe00 3141fd22a0c92953 | ..)VF...1A."..)S
467cfe282356c29e ad048145fee00800 | F|.(#V.....E....
a2a271c0aa11813e fee008008142fee0 | ..q....>.....B..
0800c673fe000028 3316829cad04813c | ...s...(3......<
fee00800a2a3e881 36fee00800e00200 | ........6.......
466cfe1df0000000 3641009d0282a0c0 | Fl......6A......
280387990fcc320c 128607000c022903 | (.....2.......).
7ce2860f00261207 2622188603000000 | |....&..&"......
82a0db8029238799 2a0c2229037cf246 | ....)#..*.").|.F
0800000022a0dc27 990a0c1229032d08 | ...."..'....).-.
060400000082a0dd 7cf28799060c1229 | ........|......)
0322a0db1df00000 | ."......
TRACE +0.005 Write 3534 bytes:
c00007680d5e0000 00580d0000000000 | ...h.^...X......
0000000000000000 000800f43f1c00f4 | ............?...
3f0000f43f00dbdc fc3f1000f43f3641 | ?...?....?...?6A
0021faffdbdc2000 380241f9ffdbdc20 | .!.... .8.A....
0028042020749ce2 060500000041f5ff | .(. t.......A..
81f6ffdbdc2000a8 048808a0a074e008 | ..... .......t..
000b226602e786f4 ff21f1ffdbdc2000 | .."f.....!.... .
39021df00000a0eb fd3f186bfd3f8480 | 9........?.k.?..
00004040000058ab fd3fa4ebfd3f3641 | ..@@..X..?...?6A
00b1f9ff20a07410 1120a5c700961a06 | .... .t.. ......
81f6ff92a1019099 119a98dbdc2000b8 | ............. ..
0991f3ffa0a0749a 88dbdc2000921800 | ......t.... ....
9090f41bc9dbdcdb dcf4dbdc2000c258 | ............ ..X
009a9bdbdc2000a2 4900dbdc20009218 | ..... ..I... ...
0081eaff9090f480 80f487994781e5ff | ............G...
92a1019099119a98 dbdc2000c809a1e5 | .......... .....
ffb1e3ff879c17c6 01007ce8871adec6 | ..........|.....
0800dbdc2000890a dbdc2000b9094602 | .... ..... ...F.
00dbdc2000b90adb dc2000890991d7ff | ... ..... ......
9a880c09dbdc2000 9258001df00000f8 | ...... ..X......
20f43ff830f43f36 410091fdffdbdc20 | .?.0.?6A......
0088098080245648 ff91faffdbdc2000 | .....$VH...... .
88098080245648ff 1df00000001020f4 | ....$VH....... .
3f0020f43f000000 08364100101120a5 | ?. .?....6A... .
fcff21faff0c08db dc200082620091fa | ..!...... ..b...
ff81f8ffdbdc2000 926800dbdc200098 | ...... ..h... ..
085679ffdbdc2000 88027cf280223020 | .Vy... ...|.."0
20041df000000000 40364100101120e5 | .......@6A... .
fbff166aff81ecff 91fbffdbdc200092 | ...j......... ..
6800dbdc20009808 5679ff1df000000c | h... ...Vy......
dbdcfc3fffffff00 0420f43f36410021 | ...?..... .?6A.!
fcff384216830610 112065f8ff16fa05 | ..8B..... e.....
0cf80c0437a80d98 2280991082a00190 | ....7...".......
4883404074101120 25faff10112025f3 | H.@@t.. %.... %.
ff88220c1b409811 90ab01cc1480ab01 | .."..@..........
b1edffb09910b1ec ffdbdc2000926b00 | ........... ..k.
91ceffdbdc2000a2 6900dbdc2000a809 | ..... ..i... ...
567aff1c090c1a40 9a839033dbdc9a88 | Vz.....@...3....
394289221df00000 2c920040364100a2 | 9B."....,..@6A..
a0dbdc81fdffe008 001df00000364100 | .............6A.
82a0dbdcad028792 11a2a0dbdd81f7ff | ................
e00800a2a0dc4604 0000000082a0dbdd | ......F.........
87920881f2ffe008 00a2a0dd81f0ffe0 | ................
08001df03641003a 32c6020000a20200 | ....6A.:2.......
1b22101120a5fbff 3792f11df0000000 | .".. ...7.......
7cda0540d82e0640 9cda05401cdbdd05 | |..@...@...@....
40362121a2d11081 faffe00800460b00 | @6!!.........F..
00000c1440441140 4363cd04bd01ad02 | ....@D.@Cc......
81f5ffe00800a0a0 74fc5acd0410b120 | ........t.Z....
a2d11081f1ffe008 004a224033dbdc56 | .........J"@3..V
03fd22a20b1022b0 20a220b2d11081ec | .."...". . .....
ffe00800ad021c0b 101120a5f7ff2d03 | .......... ...-.
86000022a0631df0 0000fc670040d092 | ...".c.....g.@..
0040086800403641 2162a107dbdc6611 | .@.h.@6A!b....f.
1a6659062c0a62d1 100c0552661a81f7 | .fY.,.b....Rf...
ffe008000c184088 1147b802464500ad | ......@..G..FE..
0681d4ffe0080086 34000092a41d5073 | ........4.....Ps
dbdce099111a9940 77638909cd07bd01 | .......@wc......
8070558037b5b092 a107dbdc99111a99 | .pU.7...........
98098075dbdc97b7 0246dcff86e6ff0c | ...u.....F......
0882466ca2a41b10 aaa081caffe00800 | ..Fl............
560affb2a20ba206 6c10bbb0101120a5 | V.......l..... .
8f00f7ea12f6470f b2a20d10bbb07abb | ......G.......z.
a24b001b7786f1ff 7cebb79ac1664708 | .K..w...|....fG.
82261a37b80287b5 9c22a20b1022b060 | .&.7....."...".`
b620ad02819bffe0 0800101120a5dfff | . .......... ...
ad021c0b10112025 e3ff101120a5deff | ...... %.... ...
2c0a81b1ffe00800 1df00820f43f70e2 | ,.......... .?p.
fa3f48240640f022 0640366100101120 | .?H$.@.".@6a...
e5caff10a12081fb ffe008003d0a0c12 | ..... ......=...
fc2a880192a20090 88108901101120a5 | .*............ .
cfff91f2ffa0a201 dbdc2000822900a0 | .......... ..)..
8820dbdc20008269 00b22100a1edff81 | . .. ..i..!.....
eeffe00800a02383 1df00000ff0f0000 | ......#.........
364100813bff0c19 924800309c419928 | 6A..;....H.0.A.(
91fbff3918293830 30b49a222a33303c | ...9.)800.."*30<
410c022958394810 112025f8ff2d0a8c | A..)X9H.. %..-..
1a22a0c51df00000 502d064036410041 | ."......P-.@6A.A
2cff583450336316 630458145a53505c | ,.X4P3c.c.X.ZSP\
4146010010112065 caff8844a6180488 | AF.... e...D....
2487a5ef101120a5 c2ff166affa814cd | $..... ....j....
03bd0281f1ffe008 00a0a0748c4a52a0 | ...........t.JR.
c452640558143a55 591458343055dbdc | .Rd.X.:UY.X40U..
59341df00000dbdc fc3f4f484149a8eb | Y4.......?OHAI..
fd3f70e00b4014e0 0b400c00f43f3840 | .?p..@...@...?8@
f43fffff00008c80 000010400000aceb | .?.........@....
fd3fbcebfd3f04db dcfc3f08dbdcfc3f | .?...?....?....?
04ecfd3f1400f43f f0ffff00a8ebfd3f | ...?...?.......?
18ebfc3f24dbdcfc 3f7c680040ec6700 | ...?$...?|h.@.g.
40588600406c2a06 4038320640142c06 | @X..@l*.@82.@.,.
40cc2c06404c2c06 4034850040cc9000 | @.,.@L,.@4..@...
40782e064030ef05 40589200404c8200 | @x..@0..@X..@L..
4036c10021deff0c 0a22610842a00081 | @6..!...."a.B...
eeffe0080021d9ff 31daffc600004902 | .....!..1.....I.
4b223732f8101120 65c3ff0c4ba2c120 | K"72... e...K..
101120e5c6ff22a1 0110112025c2ff51 | .. ...".... %..Q
91fe9022112a2531 cfffb1cfffdbdc20 | ...".*%1.......
0059022178fe0c0c 0c5a32620081dcff | .Y.!x....Z2b....
e0080031caff42a1 01dbdc200028032c | ...1..B.... .(.,
0a402220dbdc2000 29038131ffe00800 | .@" .. .)..1....
81d5ffe0080021c3 ffdbdc20002802cc | ......!.... .(..
ba1cc330221022c2 f80c1320a3830c0b | ...0".".... ....
81ceffe00800f1bc ff0c1dc2a0010c1b | ................
e2a10040dd1100cc 1180bb01a2a00081 | ...@............
c7ffe0080021b6ff 0c042a5521c3fe72 | .....!....*U!..r
d22bdbdc20002805 1672ffdbdc200038 | .+.. .(..r... .8
050c12dbdc200049 052241102203010c | ..... .I."A."...
6642112823dbdc20 0028022951460100 | fB.(#.. .(.)QF..
001c222251091011 20a5b3ff0c8ba2c1 | ..""Q... .......
1010112065b7ff82 0303220302808811 | ... e.....".....
2088202198ff2020 f487b21ca2a0dbdc | . !.. ........
10112025b2ffa2a0 ee101120a5b1ff10 | .. %....... ....
112025b0ff86dbdd ff00002203011c39 | . %........"...9
273934f62218c6d4 00000022c22f2020 | '94."......"./
74f642709189ff90 22a02802a0020022 | t.Bp....".(...."
c2fe2020741c1927 b902c6cb009184ff | .. t..'........
9022a02802a00200 92c230909074b659 | .".(......0..t.Y
c906c6002c4a6d04 22a0dbdca7180206 | ....,Jm.".......
c40049510c72ad04 101120e5aaffad04 | ..IQ.r.... .....
10112065aaff1011 20e5a8ff101120a5 | .. e.... ..... .
a8ff0c8ba2c11022 c2ff101120e5abff | .......".... ...
5622fd4629000c12 56c82c82610f817a | V".F)...V.,.a..z
ffe0080088f1a028 83c6ae002688040c | .......(....&...
12c6ac0098236833 6089208080b456d8 | .....#h3`. ...V.
fe99c110112065c7 ff98c16a299c2a06 | ..... e....j).*.
f7ff0000a0ac4181 6dffe0080056eafc | ......A.m....V..
62d6f060a2dbdccc 2606810000a090f4 | b..`....&.......
5619fe860400a0a0 f599c18165ffe008 | V...........e...
0098c1569afa9066 dbdc0c1900991160 | ...V...f.......`
a2dbdc6739e10604 000000a0ac41815c | ...g9........A.\
ffe0080056aaf862 d6f060a2dbdc56a6 | ....V..b..`...V.
fec66f00006d0422 a0dbdc268802868d | ..o..m."...&....
006d040c02c68b00 000026b8f3866100 | .m........&...a.
0c1226b802068500 b833a823101120e5 | ..&......3.#.. .
a1ffa02483068100 0c1c66b853884320 | ...$......f.S.C
ac116d0422a0c287 ba02867e00b853a8 | ..m."......~..S.
23c9e1101120e5db dcffc60b000c1c66 | #.... .........f
b82f884320ac116d 0422a0c287ba0286 | ./.C ..m."......
75002833b853a823 206882c9e1101120 | u.(3.S.# h.....
65beff2134fe4962 22d22b6922c8e1a0 | e..!4.Ib".+i"...
c4832d0c866900a1 2ffe6d04b20a0022 | ..-..i../.m...."
a0c6163b1a982382 c8f022a0dbdc8799 | ...;..#...".....
01285a0c09a2a0ef 4602009ab3b20b18 | .(Z.....F.......
1b99b0aa308729f2 8203059203048088 | ....0.).........
119088209203066d 0400991180992082 | ... ...m...... .
0307808801908820 80aadbdc82a0c1a0 | ....... ........
28934655008118fe 6d04a2080022a0c6 | (.FU....m...."..
167a14a83822a0c8 56fa132858a24800 | .z..8"..V..(X.H.
c64d001c8a6d040c 12a71802c64a00f8 | .M...m.......J..
73e863d853c843b8 33a823810cffe008 | s.c.S.C.3.#.....
006d0aa024834644 00000c1226480246 | .m..$.FD....&H.F
3f00a823bd048104 ffe00800061e0080 | ?..#............
b0346d0422a0dbdc 560b0f8064418bc3 | .4m."...V...dA..
7cfd460e00a83cb9 c1c9e1d9d18100ff | |.F...<.........
e00800c8e1b8c128 2c981ca80cd2210d | .......(,.....!.
90921026020edbdc 2000e22a00202d30 | ...&.... ..*. -0
e02210209920dbdc 2000990a1bbbc2cc | .". . .. .......
10673bc2c69bff66 4802469aff6d0422 | .g;....fH.F..m."
a0dbdc0626000c12 26b80246210021dc | ....&...&..F!.!.
fe98538823990221 dbddfe89022d0486 | ..S.#..!.....-..
1c0061d7fe0c1bd8 0682c8f0ad042d04 | ..a...........-.
802b93d0ab8320aa 106d0422a0c656ea | .+.... ..m."..V.
05c1d1fe22a0c9e8 0c873e5380f01422 | ....".....>S..."
a0dbdc56af042d0a 4602002aa3a86a4b | ...V..-.F..*..jK
22a909ad0b20fedb dc2a9d8732ed169a | ".... ...*..2...
df21c4fef90c9902 c67bff0c12668816 | .!.......{...f..
21c1fe8802162800 82a0c8490221bdfe | !.....(....I.!..
49020c128024836d 04460100006d0422 | I....$.m.F...m."
a0ff20a074101120 e579ff60a0741011 | .. .t.. .y.`.t..
206579ff101120e5 77ff56a2be220301 | ey... .w.V.."..
1c2827381ef63202 06f7fe22c2fd2020 | .('8..2...."..
740cf827b80286f3 fe81acfe8022a028 | t..'.........".(
02a0020082a0d287 125282a0d487127a | .........R.....z
06edfe0000008833 a2a271dbdcaa1168 | .......3..q....h
2389f181b0fee008 0021a1fe91a2fedb | #........!......
dc2000280288f120 3435dbdc22119022 | . .(... 45..".."
10202320802282ad 0460b2c281a7fee0 | . # ."...`......
0800a2a3e881a4fe e0080006dbddfe00 | ................
00d853c843b833a8 23101120257dff46 | ..S.C.3.#.. %}.F
d6fe00b203032203 0280bb1120bb20b2 | ......"..... . .
cbf0a2c318101120 6599ff46cffe0022 | ....... e..F..."
0303820302618ffd 8022119836802220 | .....a..."..6."
22c2f09022631622 b298169a92909c41 | "..."c.".......A
46020099c1101120 6562ff98c1a846a6 | F...... eb....F.
1a04a826a7a9eb10 1120a55aff166aff | ...&..... .Z..j.
a816cd02b2c31881 86fee008008c3a32 | ..............:2
a0c4395638162a33 391638362023dbdc | ..9V8.*39.86 #..
2936c6b5fe820302 22c3183203030c1c | )6......"..2....
80331180332032c3 f0062300816cfe91 | .3..3 2...#..l..
1dfde8083971e099 dbdc996198270c1a | ....9q.....a.'..
97b3010c3a89f1a9 d1e9c1101120255b | ....:........ %[
ffa8d19163fee8c1 a901a162fedd09bd | ....c......b....
02c2c11cf2c11899 c1816bfee00800b8 | ..........k.....
27cd0aa87188f1a0 bbdbdcb927a033db | '...q.......'.3.
dcb808aa22a86198 c1aabbdd040c1ab9 | ....".a.........
08dbdcda8390bbdb dcd0e074cc7dd2db | ...........t.}..
dd80d0ae93166a01 ad0989f199c1c9e1 | ......j.........
1011202589ff88f1 98c1c8e192680061 | .. %.........h.a
4efd88368ca3dbdc 9f31dbdc99dbdcd6 | N..6.....1......
290056f8f5d6ac00 3149fd22a0c72953 | ).V.....1I."..)S
4600008c3c9c08c6 82fe1688a06144fd | F...<........aD.
22a0c82956467ffe 003141fd22a0c929 | "..)VF...1A."..)
53467cfe282356c2 9ead048145fee008 | SF|.(#V.....E...
00a2a271dbdcaa11 813efee008008142 | ...q.....>.....B
fee00800c673fe00 00283316829cad04 | .....s...(3.....
813cfee00800a2a3 e88136fee00800e0 | .<........6.....
0200466cfe1df000 00003641009d0282 | ..Fl......6A....
a0dbdc280387990f cc320c128607000c | ...(.....2......
0229037ce2860f00 2612072622188603 | .).|....&..&"...
00000082a0dbdd80 292387992a0c2229 | ........)#..*.")
037cf24608000000 22a0dc27990a0c12 | .|.F...."..'....
29032d0806040000 0082a0dd7cf28799 | ).-.........|...
060c12290322a0db dd1df00000c0 | ...)."........
TRACE +0.314 Read 1 bytes: c0
TRACE +0.000 Read 13 bytes: 01070400bc9dd6ef00000000c0
TRACE +0.000 Received full packet: 01070400bc9dd6ef00000000
TRACE +0.000 command op=0x05 data len=16 wait_response=1 timeout=3.000 data=9c0000000100000000180000a8ebfd3f
c000051000000000 009c000000010000 | ................
0000180000a8ebfd 3fc0 | ........?.
TRACE +0.000 command op=0x07 data len=172 wait_response=1 timeout=3.000 data=
9c00000000000000 0000000000000000 | ................
18ebfc3fd8e70b40 71e80b40f3ec0b40 | ...?...@q..@...@
ede80b408fe80b40 ede80b4049e90b40 | ...@...@...@I..@
06ea0b4078ea0b40 21ea0b4081e70b40 | ...@x..@!..@...@
a3e90b40f8e90b40 67e90b409aea0b40 | ...@...@g..@...@
8ee90b409aea0b40 5de80b40b3e80b40 | ...@...@]..@...@
ede80b4049e90b40 77e80b404ceb0b40 | ...@I..@w..@L..@
b3ec0b40a5e60b40 d7ec0b40a5e60b40 | ...@...@...@...@
a5e60b40a5e60b40 a5e60b40a5e60b40 | ...@...@...@...@
a5e60b40a5e60b40 a5e60b40f3ea0b40 | ...@...@...@...@
a5e60b40cdeb0b40 b3ec0b40 | ...@...@...@
TRACE +0.000 Write 182 bytes:
c00007ac00b70000 009c000000000000 | ................
0000000000000000 0018ebfc3fd8e70b | ............?...
4071e80b40f3ec0b 40ede80b408fe80b | @q..@...@...@...
40ede80b4049e90b 4006ea0b4078ea0b | @...@I..@...@x..
4021ea0b4081e70b 40a3e90b40f8e90b | @!..@...@...@...
4067e90b409aea0b 408ee90b409aea0b | @g..@...@...@...
405de80b40b3e80b 40ede80b4049e90b | @]..@...@...@I..
4077e80b404ceb0b 40b3ec0b40a5e60b | @w..@L..@...@...
40d7ec0b40a5e60b 40a5e60b40a5e60b | @...@...@...@...
40a5e60b40a5e60b 40a5e60b40a5e60b | @...@...@...@...
40a5e60b40f3ea0b 40a5e60b40cdeb0b | @...@...@...@...
40b3ec0b40c0 | @...@.
TRACE +0.020 Read 1 bytes: c0
Running stub...
TRACE +0.000 command op=0x06 data len=8 wait_response=1 timeout=0.200 data=00000000d8e50b40
TRACE +0.000 Write 18 bytes:
c000060800000000 0000000000d8e50b | ................
40c0 | @.
TRACE +0.000 Read 13 bytes: 01060400bc9dd6ef00000000c0
TRACE +0.000 Received full packet: 01060400bc9dd6ef00000000
TRACE +0.000 Read 5 bytes: 4f484149c0
TRACE +0.000 Received full packet: 4f484149
Stub running...
Changing baud rate to 921600
TRACE +0.000 command op=0x0f data len=8 wait_response=1 timeout=3.000 data=00100e0000c20100
c0000f0800000000 0000100e0000c201 | ................
00c0 | ..
TRACE +0.000 Read 11 bytes: 010f0200000000000000c0
TRACE +0.000 Received full packet: 010f0200000000000000
Changed.
TRACE +0.053 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=1c20f43f
TRACE +0.000 Write 14 bytes: c0000a0400000000001c20f43fc0
TRACE +0.000 Read 11 bytes: 010a0200400000800000c0
TRACE +0.000 Received full packet: 010a0200400000800000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=2420f43f
TRACE +0.000 Write 14 bytes: c0000a0400000000002420f43fc0
TRACE +0.000 Read 11 bytes: 010a0200000000700000c0
TRACE +0.000 Received full packet: 010a0200000000700000
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2c20f43f17000000ffffffff00000000
c000091000000000 002c20f43f170000 | ........., .?...
00ffffffff000000 00c0 | ..........
TRACE +0.000 Read 11 bytes: 01090200000000000000c0
TRACE +0.000 Received full packet: 01090200000000000000
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=1c20f43f00000090ffffffff00000000
c000091000000000 001c20f43f000000 | .......... .?...
90ffffffff000000 00c0 | ..........
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2420f43f9f000070ffffffff00000000
c000091000000000 002420f43f9f0000 | .........$ .?...
70ffffffff000000 00c0 | p.........
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=8020f43f00000000ffffffff00000000
c000091000000000 008020f43f000000 | .......... .?...
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=0020f43f00000400ffffffff00000000
c000091000000000 000020f43f000004 | .......... .?...
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=0020f43f
TRACE +0.000 Write 14 bytes: c0000a0400000000000020f43fc0
TRACE +0.000 Read 11 bytes: 010a0200000000000000c0
TRACE +0.000 Received full packet: 010a0200000000000000
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=8020f43f
TRACE +0.000 Write 14 bytes: c0000a0400000000008020f43fc0
TRACE +0.000 Read 11 bytes: 010a0200ffffff000000c0
TRACE +0.000 Received full packet: 010a0200ffffff000000
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=1c20f43f40000080ffffffff00000000
c000091000000000 001c20f43f400000 | .......... .?@..
80ffffffff000000 00c0 | ..........
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2420f43f00000070ffffffff00000000
c000091000000000 002420f43f000000 | .........$ .?...
WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.
TRACE +0.000 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=1c20f43f
TRACE +0.002 Read 1 bytes: c0
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2c20f43f07000000ffffffff00000000
c000091000000000 002c20f43f070000 | ........., .?...
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2020f43f0700005cffffffff00000000
c000091000000000 002020f43f070000 | ......... .?...
5cffffffff000000 00c0 | \.........
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=1c20f43f000000f0ffffffff00000000
f0ffffffff000000 00c0 | ..........
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=2420f43f5a000070ffffffff00000000
c000091000000000 002420f43f5a0000 | .........$ .?Z..
TRACE +0.000 command op=0x09 data len=16 wait_response=1 timeout=3.000 data=0420f43f10000000ffffffff00000000
c000091000000000 000420f43f100000 | .......... .?...
TRACE +0.000 Read 11 bytes: 010a0200ff0000000000c0
TRACE +0.000 Received full packet: 010a0200ff0000000000
Configuring flash size...
Warning: Could not auto-detect Flash size (FlashID=0xffffff, SizeID=0xff), defaulting to 4MB
TRACE +0.000 command op=0x0b data len=24 wait_response=1 timeout=3.000 data=
0000000000004000 0000010000100000 | ......@.........
00010000ffff0000 | ........
TRACE +0.000 Write 34 bytes:
c0000b1800000000 0000000000000040 | ...............@
0000000100001000 0000010000ffff00 | ................
00c0 | ..
TRACE +0.000 Read 11 bytes: 010b0200000000000000c0
TRACE +0.000 Received full packet: 010b0200000000000000
TRACE +0.000 Read 11 bytes: 010a0200040000000000c0
TRACE +0.000 Received full packet: 010a0200040000000000
TRACE +0.000 Read 11 bytes: 010a020000a200000000c0
TRACE +0.000 Received full packet: 010a020000a200000000
TRACE +0.000 Read 11 bytes: 010a0200000010000000c0
TRACE +0.000 Received full packet: 010a0200000010000000
TRACE +0.000 Read 11 bytes: 010a0200002004960000c0
TRACE +0.000 Received full packet: 010a0200002004960000
TRACE +0.002 command op=0x0a data len=4 wait_response=1 timeout=3.000 data=0ca0f53f
Flash will be erased from 0x00001000 to 0x00007fff...
Flash will be erased from 0x00010000 to 0x00035fff...
Flash params set to 0x0220
TRACE +0.000 command op=0x02 data len=16 wait_response=1 timeout=3.000 data=10650000020000000040000000100000
c000021000000000 0010650000020000 | ..........e.....
0000400000001000 00c0 | ..@.......
TRACE +0.000 Read 8 bytes: 0102020000000000
TRACE +3.003 Packet content transfer stopped (received 8 bytes)
A fatal error occurred: Packet content transfer stopped (received 8 bytes)
