Can't get or set hostname on netif
rpoelvogels
Postby rpoelvogels » Fri Oct 06, 2023 8:40 am
I'm trying to set the hostname for the ethernet interface.
But `esp_netif_set_hostname()` always returns `ESP_ERR_ESP_NETIF_IF_NOT_READY`.
`esp_netif_get_hostname()` also always only returns `ESP_ERR_ESP_NETIF_IF_NOT_READY`.
I've checked the source code of these functions and they look like:
#if LWIP_NETIF_HOSTNAME
//Useful code
#else
    return ESP_ERR_ESP_NETIF_IF_NOT_READY;
#endif
`LWIP_NETIF_HOSTNAME` is defined as '0', so the useful code is removed.
How and where can I make sure that `LWIP_NETIF_HOSTNAME` is properly defined?
I'm using ESP-IDF 4.4.
Thanks in advance.
Kind regards,
Remco Poelstra
chegewara
Re: Can't get or set hostname on netif
Postby chegewara » Tue Mar 19, 2024 4:17 pm
When you init ethernet netif with this or similar API:
ethernetif_init()
you can use thi API w/o issues
esp_netif_set_hostname(esp_netif, name)
