mcpwm_set_frequency() equivalent for esp-idf v5.0
Hello Community,
Does anyone have a working example of how to update the PWM frequency using the new mcpwm driver in IDF v5.0? This was simple in v4.4 using the provided mpcwm_set_frequency() function, however in IDF v5.0, mcpwm_set_frequency was removed. According to the migration documentation from https://docs.espressif.com/projects/esp ... erals.html
"mcpwm_set_frequency: PWM frequency is determined by mcpwm_timer_config_t::resolution_hz, mcpwm_timer_config_t::count_mode and mcpwm_timer_config_t::period_ticks."
It's not clear what the steps are to actually change the frequency of the PWM while maintaining for example a steady 50% duty cycle.
Re: mcpwm_set_frequency() equivalent for esp-idf v5.0
have you looked at any of the examples here ?
https://github.com/espressif/esp-idf/tr ... rals/mcpwm
Yes, thanks for the suggestion. I did look through all of those and ran the mcpwm_servo_control on my ESP32-S3 to generate a PWM signal. The mcpwm_bldc_speed_control is almost what I need except it modulates duty cycle to control speed and I need to modulate frequency. I know there has to be a simple way to dynamically update the frequency of the PWM signal like while a stepper motor is stepping, but I'm just not finding enough of a clue in these examples and don't know enough about the v5.0 implementation of PWM control. I understand how the comparator is used to change duty cycle for a constant frequency PWM output, but then how do you change the period_ticks of the mcpwm_timer?
Thanks for reporting. Yes, we will provide an API to change the period dynamically.
New API available on the master branch now: https://github.com/espressif/esp-idf/co ... 2bfd341a70
We will backport that API to release/v5.0 and release/v5.1 as well.
@esp_morris
Was this also backported to 5.1?
Thanks!
Thanks!
Whether API has been added, I found that the programming guide of 5.2.1 still does not mention setting (or adjusting) PWM operating frequency. Also, how to set up two sets of MCPWM in version 5?Thanks for reporting. Yes, we will provide an API to change the period dynamically.
Version 5 of MCPWM is much more complex than version 4. Version 5 introduces a series of concepts including generators and comparators. resolution_hz should be the granularity of the specified timer and period_ticks/resolution_hz should be the PWM period.Hello Community,
As for whether period_tick is related to the set duty cycle, I don't understand it yet (and this process also needs to generate mcpwm_comparator_set_compare_value through comparator comparison value, and the input value is a uint32_t volume value. Simple guess period_tick can be understood as the graininess in PWM period, and the duty cycle of 50% should be period_tick*0.5). The new MCPWM is too hard to learn.
I looked at LEDC examples, and if you don't mind, LEDC can actually meet your needs.
Users browsing this forum: Amazon [Bot], ChatGPT-User, Semrush [Bot] and 1 guest
