I'm currently working on a project using the ESP32-S3 chip, and I've decided to use MicroPython for my coding. In my project, I have connected GPIO 39 and GPIO 40 to relays for various operations. The ESP32-S3 datasheet designates GPIO 39 as MTCK and GPIO 40 as MTDO, which are typically used for JTAG debugging and programming.
However, I'm not utilizing JTAG programming for my project. My question is, do I need to perform any separate initialization or special configurations for GPIO 39 and GPIO 40, or is it sufficient to initialize them as regular output pins using MicroPython for my relay control?
I want to make sure that my project runs smoothly while making the best use of these GPIO pins. Any insights or guidance on this matter would be greatly appreciated.
Thanks,
Kowshik
MTCK and MTDO pins in ESP32S3
Re: MTCK and MTDO pins in ESP32S3
You can initialize these pins as GPIO pins. No issues. If you ever need to use JTAG for programming or debugging, you might need to disable their use as regular GPIOs and configure them back to their default JTAG functions.
Users browsing this forum: Qwantbot and 3 guests
