ESP32 wakeup with sound sensor
beavis6511
Postby beavis6511 » Sat Oct 21, 2023 3:37 pm
I would like to wake up my esp32 (in deep sleep) when the sound sensor detects a sound.
The output of the sensor is not 0/1 but a voltage value, according to the sound level.
Is it possible to do this ?
I've tried with this code but it is not working. After going to sleep, it wakes up immediately
#define SENSOR_PIN 33
#define S_TO_MS_FACTOR 1000
#define ALIVE_TIME_S  5 // Time in seconds to stay alive, before going to deep sleep
int lastState = HIGH;  // the previous state from the input pin
int currentState;      // the current reading from the input pin
RTC_DATA_ATTR int bootCount = 0;
unsigned long timer = 0;
bool timer_started = false;
void setup() {
  Serial.begin(115200);
  pinMode(SENSOR_PIN, INPUT);
  Serial.println("Setup");
  ++bootCount;
  Serial.println("Boot number: " + String(bootCount));
  esp_sleep_enable_ext0_wakeup(GPIO_NUM_33, 0); //1 = High, 0 = Low
void loop() {
  // Deep Sleep
  if (!timer_started) {
    Serial.println("Start timer");
    timer = millis();
    timer_started = true;
  if (millis() - timer >= (ALIVE_TIME_S * S_TO_MS_FACTOR)) {
    Serial.println("going to sleep...");
    esp_deep_sleep_start();
Thanks !
MicroController
Re: ESP32 wakeup with sound sensor
Postby MicroController » Sun Oct 22, 2023 10:03 am
Sounds like you'd want to use the ULP to read the voltage level via the ADC, like in this example.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
