TX UART open drain mode
freddy_13
Postby freddy_13 » Fri Nov 10, 2023 2:22 pm
I am trying to use GPIO 21 on ESP32 C3 for UART0 TX. I would like uses it with open drive feature.
I have tried with API and with register level instructions.
In API the instructions are the follow:
ESP_ERROR_CHECK(uart_param_config(S_BusPort, &uart_config_1));
ESP_ERROR_CHECK (uart_driver_install(S_BusPort, 1024, 1024, 0, NULL, 0));
ESP_ERROR_CHECK(uart_set_pin(S_BusPort, 21, 20, -1, -1));
ESP_ERROR_CHECK(gpio_set_direction (GPIO_NUM_21, GPIO_MODE_OUTPUT_OD));
ESP_ERROR_CHECK(gpio_pullup_en(GPIO_NUM_21));
The TX UART signal come out properly but not in open drain mode (both the rising and falling fronts are very steep).
Using register the instruction are the follow:
REG_WRITE(GPIO_FUNC21_OUT_SEL_CFG_REG,0x006); //connect UART0 output signal to GPIO21
REG_WRITE(GPIO_PIN21_REG,0x04); //open drain activated
REG_WRITE(IO_MUX_GPIO21_REG,0x0900); //pull up activated
Also in this case the output UART signal come out properly but not in open drain mode.
Is there some thing wrong? Can someone help me? Or, simply, doesn’t ESP32 C3 support open drain mode when the GPIO is linked to the UART0 TX signal?
Thanks in advance.
Best regards,
Freddy_13
brunohpg
Re: TX UART open drain mode
Postby brunohpg » Fri Apr 12, 2024 7:44 pm
Did you found a way to use od in uart tx?
In esp-idf 4.4 it works using:
gpio_set_direction(tx_io_num, GPIO_MODE_OUTPUT_OD)
But not in 5.2.
brunohpg
Postby brunohpg » Fri Apr 12, 2024 8:32 pm
I saw that new implementation connects gpio to gpio out signal when set direction.
I think one pad can be connected to only one signal. Then the serial signal are disconnected.
static esp_err_t gpio_output_enable(gpio_num_t gpio_num)
    GPIO_CHECK(GPIO_IS_VALID_OUTPUT_GPIO(gpio_num), "GPIO output gpio_num error", ESP_ERR_INVALID_ARG);
    gpio_hal_output_enable(gpio_context.gpio_hal, gpio_num);
    esp_rom_gpio_connect_out_signal(gpio_num, SIG_GPIO_OUT_IDX, false, false);
    return ESP_OK;
You can do an hack:
	#include "hal/gpio_hal.h"
        gpio_hal_context_t hal = {.dev = GPIO_HAL_GET_HW(GPIO_PORT_0)};
        gpio_hal_od_enable(&hal, tx_io_num);
FiwiDev
Postby FiwiDev » Sat Dec 14, 2024 5:55 pm
I'm working on implementing half-duplex bidirectional UART communication on a single GPIO line with an original ESP32. Setup fixes for single-line UART have been published to the latest ESP-IDF...but they aren't present in ESP-IDF v5.1 (for Arduino-ESP32 v3.0.7). Independently found a similar solution to what you wrote above, also adding a weak pullup.
static gpio_hal_context_t _gpio_hal = {
gpio_hal_od_enable(&_gpio_hal, pin);
gpio_pullup_en((gpio_num_t)pin);
Works perfectly on an (original) ESP32 for open-drain UART TX, verified with an oscilloscope. As the ESP32 "weak pullup" is approx 50K, a 10K resistor loads it down to almost nothing, proving that it's in open-drain mode. (If the ESP32 GPIO is not in open-drain mode, a 10K load resistor has zero effect.)
Now to see if RX is actually on the same pin (as per the UART "setPins" request)...and if not, I'll have to backport the fixes with another hack. Fun times!
Users browsing this forum: meta-externalagent, Qwantbot and 1 guest
