WT32-ETH01 want work Wi-Fi to Ethernet.
lstpvtltd
Postby lstpvtltd » Fri Nov 17, 2023 6:45 am
My application is communicate HMI (Ethernet) to Server (Via Wifi Access point). Need Static IP for Wifi and Ethernet. If I can setup WT32-ETH01 via webui is very much better. coz each device connect to different IP Address.
Oleg_K
Re: WT32-ETH01 want work Wi-Fi to Ethernet.
Postby Oleg_K » Sat Nov 25, 2023 7:25 pm
There are: a WT32-ETH01 board, as well as an IP camera with an Ethernet interface BLK18C-0222-38X38_S. I am faced with the task of transmitting the IP camera signal via WiFi. Is it possible to organize the transmission of the camera signal via Wi-Fi using WT32-ESH01? How to set up the board for this?
novlean
Postby novlean » Wed Mar 19, 2025 4:05 pm
For easy WebUI setup you can try a Mongoose Wizard https://mongoose.ws/wizard/.
It is a is a no-code tool you can use to build WebUI for your ESP32 powered devise without writing any frontend code.
Users browsing this forum: Bytespider, PetalBot and 7 guests
