Now I'm doing authorization on ESP32 and I ran into a problem.
I know there are build-in basic and digest authorization, but as frontend I use Vue.js framework and I want to do separate page for authorization.
The solutions I am currently using:
1) when loading the page / I'm initializing the authenticated = false variable. Later, in the code, when authorization is successful, it changes the value. One of the disadvantages of this approach is that if I refresh the page, I will have to re-enter the login password.
2) I tried using
user_ctxSome code from 2):
in header
typedef struct rest_server_context
char base_path[ESP_VFS_PATH_MAX + 1];
char scratch[SCRATCH_BUFSIZE];
bool authenticated;
} rest_server_context_t;Code: Select all
// here is auth = OK, continue
if (!req->sess_ctx)
req->sess_ctx = malloc(sizeof(rest_server_context_t)); /*!< Pointer to context data */
req->free_ctx = free_ctx_func; /*!< Function to free context data */
((rest_server_context_t *)(req->user_ctx))->authenticated = true;
bool is_authenticated(httpd_req_t *req)
rest_server_context_t *context = (rest_server_context_t *)req->user_ctx;
if (req->user_ctx)
bool auth = context->authenticated;
ESP_LOGW("AUTH TAG", "Authenticated is %d", auth);
if (auth)
return true;
return false;
}The main question is:
How to split client sessions on the server and check exactly a specific client session? Is it possible to access exactly the current user session and change its data?
Thank you!
