[SOLUTION HERE] Http server authorization using cookie!
sazanof
Contact:
Postby sazanof » Sat Feb 01, 2025 7:25 pm
Hello.
I am using a POST request to the HTPP server on ESP32 to verify the user's authorization and set up a session.
n the context of the request, I can get the
sockfd
descriptor ID, but it is different for different URLs. Is there any way I can get a
unique client session ID
to add it to the session context and save it to ESP32? Thanks!
MicroController
Re: UNIQUE session identifier (http server)
Postby MicroController » Sun Feb 02, 2025 12:08 pm
Normally, you set a cookie with the session ID in the first response and extract the session ID from the cookies sent with every subsequent request (https://en.wikipedia.org/wiki/HTTP_cook ... management).
sazanof
Contact:
Postby sazanof » Tue Feb 04, 2025 6:02 am
Thank you so much for your help! I'll probably do that. Another option is to simply store a variable in the code when querying index.html . And it's okay that when you request index.html , the variable will reset to zero. Not really ok, but acceptable too.
sazanof
Contact:
Re: [SOLUTION HERE] Http server authorization using cookie!
Postby sazanof » Fri May 16, 2025 7:11 am
So, i found solution and it works.
0)
 #define AUTH_COOKIE_KEY "auth-token"
1) Create struct
typedef struct
    uint64_t timestamp;
    uint8_t fd;
} um_webserver_token_t;
static um_webserver_token_t auth_token;
2) Create basic methods, that operates with token
 * Get user token from request
 * @param   char  out
 * @return  void
static void um_webserver_get_auth_token(httpd_req_t *req, char *out)
    size_t size = 36;
    httpd_req_get_cookie_val(req, AUTH_COOKIE_KEY, out, &size);
 * Add user token to token store
 * @return  void    [return description]
static void um_webserver_add_auth_user(um_webserver_token_t token)
    auth_token.fd = token.fd;
    auth_token.timestamp = token.timestamp;
 * Delete user token from token store
 * @return  void
static void um_webserver_delete_user_token(httpd_req_t *req)
    auth_token.fd = 0;
    auth_token.timestamp = 0;
3) In login http handler
if (strcmp(password, nvs_password) == 0 && strcmp(username, nvs_username) == 0)
            success = true;
            // Add user token to store
            char token[36];
            um_webserver_token_t user_token = {
                .fd = httpd_req_to_sockfd(req),
                .timestamp = esp_timer_get_time()};
            um_webserver_add_auth_user(user_token);
            sprintf(token, AUTH_COOKIE_KEY "=%lld:%d; Path=/; HttpOnly", user_token.timestamp, user_token.fd);
            // Send cookie header to browser
            // https://developer.mozilla.org/en-US/docs/Web/HTTP/Reference/Headers/Set-Cookie
            httpd_resp_set_hdr(req, "Set-Cookie", token);
4) In private handlers use
static esp_err_t some_private_method(httpd_req_t *req)
    httpd_resp_set_type(req, "application/json");
    if (um_webserver_is_authenticated(req))
       // Your code
    return ESP_OK;
When the user is logged in successfully - we send cookie to browser. Browser remember that cookie and send back to server. Server will check cookie in private request.
MicroController
Postby MicroController » Fri May 16, 2025 8:25 am
A note on security: Using a timestamp as a 'unique' and 'unpredictable' session ID is generally considered pretty insecure, as timestamps tend to have little entropy and are easily predicted/extrapolated by an adversary. For better security, session IDs are usually long (e.g. 128 bits) fully-random numbers.
sazanof
Contact:
Postby sazanof » Fri May 16, 2025 8:36 am
That is right, thanks! It is just for tests
Users browsing this forum: Bytespider, PerplexityBot, Qwantbot and 11 guests
