ESP32 UWB WROVER Guru Meditation error
lewthomps
Postby lewthomps » Thu Nov 23, 2023 4:57 am
Hi All,
I'm using a Mac running Monterey and attempting to run the example code on Arduino IDE for the ESP32 UWB, but it runs into this error:
Guru Meditation Error: Core  1 panic'ed (Interrupt wdt timeout on CPU1).
Core  1 register dump:
PC      : 0x4008ac3a  PS      : 0x00060735  A0      : 0x80089bb2  A1      : 0x3ffbf18c
A2      : 0x3ffb7d84  A3      : 0x3ffbd330  A4      : 0x00000004  A5      : 0x00060723
A6      : 0x00060723  A7      : 0x00000001  A8      : 0x3ffbd330  A9      : 0x00000018
A10     : 0x3ffbd330  A11     : 0x00000018  A12     : 0x3ffc2794  A13     : 0x00060723
A14     : 0x007bf338  A15     : 0x003fffff  SAR     : 0x0000001e  EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000  LBEG    : 0x400841e1  LEND    : 0x400841e9  LCOUNT  : 0x00000027
Core  1 was running in ISR context:
EPC1    : 0x400dfb6b  EPC2    : 0x00000000  EPC3    : 0x00000000  EPC4    : 0x00000000
Backtrace: 0x4008ac37:0x3ffbf18c |<-CORRUPTED
Core  0 register dump:
I did not touch the code. It is straight copied and pasted from the git repository, which led me to believe it would work without a hitch!
It seems to have an issue with this line:
DW1000Ranging.initCommunication(PIN_RST, PIN_SS, PIN_IRQ);
But I can't figure out why or what needs to be changed to get this code to run correctly.
Any help would be greatly appreciated!!!
Best
Lewis
