ESP32 - Guru Meditation Error: Core 1 panic'ed (LoadProhibited)
CCooper1971
Postby CCooper1971 » Wed Dec 06, 2023 9:36 pm
Hi All,
Need some help here.
Running an ESP32 WROOM and using 2 x I2S interfaces (In (Microphone) & Out (Amplifier))), I2C interface and SPI interface. The I2C controls a Texas Instruments Class D Amplifier, while the SPI connects to an SD card for WAV & MP3 files.
This functionality all works and I can play MP3 tracks or switch to the I2S microphone all satisfactorily.
However, I need to enable ESP NOW and as soon as I do, I get a boot loop when the setup function calls:
	// Initialise WiFi ESP Now
	if (esp_now_init() != ESP_OK) {
		Serial.println("Error initializing ESP-NOW");
		return;
	else Serial.println("ESP initialized succesfully");
The error is as follows:
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core  1 register dump:
PC      : 0x400f3228  PS      : 0x00060830  A0      : 0x800d556b  A1      : 0x3ffb2130
A2      : 0x3ffc3df4  A3      : 0x3ffc0a84  A4      : 0x3ffc3df4  A5      : 0x00000000
A6      : 0x00000080  A7      : 0x000000d1  A8      : 0x800d975c  A9      : 0x3ffb2110
A10     : 0x000007d0  A11     : 0x3ffbf448  A12     : 0x00000006  A13     : 0x00000001
A14     : 0x0000001e  A15     : 0x3ffb5ba0  SAR     : 0x00000011  EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000004c  LBEG    : 0x40087b7d  LEND    : 0x40087b8d  LCOUNT  : 0xffffffff
Backtrace: 0x400f3225:0x3ffb2130 0x400d5568:0x3ffb2150 0x400db11a:0x3ffb2290
ELF file SHA256: a0a6f367b418dd65
My sketch is as follows:
// I2S & Amplifier Test Sketch
// Christopher Cooper - December 2023
// Include required libraries
#include "Arduino.h"
#include <esp_now.h>
#include <WiFi.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <FS.h>
#include <AudioConfig.h> // Phil Schatzmann Audio Tools Library
#include <AudioLogger.h> // Phil Schatzmann Audio Tools Library
#include <AudioTools.h>  // Phil Schatzmann Audio Tools Library
#include <AudioCodecs/AudioCodecs.h> // Phil Schatzmann Audio Tools Library
 // MicroSD Card Reader connections
#define SD_CS 5
#define SPI_MOSI 23
#define SPI_MISO 19
#define SPI_SCK 18
// I2C Connections
#define I2C_SDA 21
#define I2C_SCL 22
// I2S Channle One
#define I2S_DIN_0 13
#define I2S_BCLK_0 14
#define I2S_LRC_0 15
// I2s Channel Two
#define I2S_DOUT_1 16
#define I2S_BCLK_1 4
#define I2S_LRC_1 17
#define I2S_MCLK_1 0
// TAS5760L registers
#define TAS5760L_ADDRESS 0x6C
#define TAS5760L_PWRCTRL 0x01
#define TAS5760L_DIGCTRL 0x02
#define TAS5760L_ANALOGCTRL 0x06
#define TAS5760L_VOLCONFIG 0x30
#define TAS5760L_LEFTVOLCONFIG 0x04
#define TAS5760L_RIGHTVOLCONFIG 0x05
#define TAS5760L_FAULT 0x08
// Transmitter MAC Address. e0:98:06:85:b7:a6
uint8_t broadcastAddress[] = { 0xE0, 0x98, 0x06, 0x85, 0xB7, 0xA6 };
// Struct data set.
typedef struct struct_message_control {
	unsigned int soundClip;
} struct_message_control;
// Create a struct_message_control called myData.
struct_message_control myData;
// Create ESP now peering.
esp_now_peer_info_t peerInfo;
// Create Audio object
AudioInfo info(44100, 2, 16);
I2SStream in;
I2SStream out;
EncodedAudioStream decoder(&out, new WAVDecoder()); // Decoding stream
//EncodedAudioStream decoder(&out, new MP3DecoderHelix()); // Decoding stream
StreamCopy mp3;
StreamCopy mic(out, in);
File audioFile;
//Audio audio;
// Define pin outs
#define spkFault 33
// #define spkSleep 15
#define spkShutDown 32
#define redButton 39
#define greenButton 34
#define blueButton 35
#define blackButton 36
#define yellowButtonOne 26
#define yellowButtonTwo 25
#define singleRedButton 27
#define singleGreenButton 2
// Keep alive variables.
int failureCount = 0;           // Amount of comms failures before disable.
// Define variables
boolean tas5760lError = HIGH;
boolean amplifierEnabledFlag = LOW;
boolean amplifierEnabledFlagChanged = LOW;
boolean playerControlFlag = LOW;
boolean playerControlFlagChanged = LOW;
boolean micControlFlag = LOW;
boolean micControlFlagChanged = LOW;
boolean redButtonFlag = LOW;
boolean redButtonFlagChanged = LOW;
boolean volumeChangeFlag = LOW;
byte volumeSetting = 0;
byte volumeSettingDisplay = 0;
unsigned int playTrack = 0;
boolean longSong = LOW;
// Amplifier control interrupt
void IRAM_ATTR amplifierControlISR() {
	static unsigned long last_interrupt_time = 0;  // Function to solve debounce.
	unsigned long interrupt_time = millis();
	if (interrupt_time - last_interrupt_time > 200) {
		if (amplifierEnabledFlag == LOW) {
			amplifierEnabledFlag = HIGH;
			amplifierEnabledFlagChanged = HIGH;
		else if (amplifierEnabledFlag == HIGH) {
	last_interrupt_time = interrupt_time;
// Player control interrupt
void IRAM_ATTR playerControlISR() {
		if (playerControlFlag == LOW) {
			playerControlFlag = HIGH;
			playerControlFlagChanged = HIGH;
		else if (playerControlFlag == HIGH) {
//  Microphone control interrupt
void IRAM_ATTR micControlISR() {
		if (micControlFlag == LOW) {
			micControlFlag = HIGH;
			micControlFlagChanged = HIGH;
		else if (micControlFlag == HIGH) {
// Find I2S devices
void i2sAddress() {
	byte error, address;
	int nDevices = 0;
	delay(1000);
	Serial.println("Scanning for I2C devices ...");
	for (address = 0x01; address < 0x7f; address++) {
		Wire.beginTransmission(address);
		error = Wire.endTransmission();
		if (error == 0) {
			Serial.printf("I2C device found at address 0x%02X\n", address);
			nDevices++;
		else if (error != 2) {
			Serial.printf("Error %d at address 0x%02X\n", error, address);
	if (nDevices == 0) {
		Serial.println("No I2C devices found");
	delay(1000);
// Write I2C register function
void writeRegister(uint8_t address, uint8_t reg, int value) {
	Wire.write(reg);
	Wire.write(value);
// Read I2C register function
int readRegister(uint8_t address, uint8_t reg) {
	Wire.write(reg);
	Wire.endTransmission(false);
	Wire.requestFrom(static_cast<uint8_t>(address), static_cast<uint8_t>(1)); // Explicit casting
	if (Wire.available()) {
		return Wire.read();
	return -1;
// Display registers
void displayRegisterValues() {
	// Read and display the values of specific registers
	byte whoAmI = readRegister(TAS5760L_ADDRESS, 0x00);
	byte pwrCtrl = readRegister(TAS5760L_ADDRESS, TAS5760L_PWRCTRL);
	byte digCtrl = readRegister(TAS5760L_ADDRESS, TAS5760L_DIGCTRL);
	byte analogCtrl = readRegister(TAS5760L_ADDRESS, TAS5760L_ANALOGCTRL);
	byte volConfig = readRegister(TAS5760L_ADDRESS, TAS5760L_VOLCONFIG);
	byte volLeft = readRegister(TAS5760L_ADDRESS, TAS5760L_LEFTVOLCONFIG);
	byte volRight = readRegister(TAS5760L_ADDRESS, TAS5760L_RIGHTVOLCONFIG);
	byte fault = readRegister(TAS5760L_ADDRESS, TAS5760L_FAULT);
	// Print register values to the serial monitor
	Serial.println();
	Serial.println("Register Values:");
	Serial.println();
	Serial.print("TAS5760L Who Am I:       0x");
	Serial.println(whoAmI, HEX);
	Serial.print("TAS5760L Power Control:  0x");
	Serial.println(pwrCtrl, HEX);
	Serial.print("TAS5760L Digital Control:0x");
	Serial.println(digCtrl, HEX);
	Serial.print("TAS5760L Analog Control: 0x");
	Serial.println(analogCtrl, HEX);
	Serial.print("TAS5760L Volume Config:  0x");
	Serial.println(volConfig, HEX);
	Serial.print("TAS5760L Volume Left  :  0x");
	Serial.println(volLeft, HEX);
	Serial.print("TAS5760L Volume Right :  0x");
	Serial.println(volRight, HEX);
	Serial.print("TAS5760L Fault:          0x");
	Serial.println(fault, HEX);
// Display amplifier faults
void displayFaultRegister() {
	Serial.println(fault, BIN);
// Configure digital control registers
void configureDigCtrlRegisters() {
	// Set FUNC_CFG_ACCESS and PIN_CTRL registers
	writeRegister(TAS5760L_ADDRESS, TAS5760L_DIGCTRL, B00010100);
// Configure analog control registers
void configureAnalogCtrlRegisters() {
	writeRegister(TAS5760L_ADDRESS, TAS5760L_ANALOGCTRL, B11010001);
// Configure shutdown registers
void shutDownRegisters() {
	writeRegister(TAS5760L_ADDRESS, TAS5760L_PWRCTRL, B11111110);
// Configure start up registers
void startUpRegisters() {
	writeRegister(TAS5760L_ADDRESS, TAS5760L_PWRCTRL, B11111101);
// Configure mute registers
void muteRegisters() {
	writeRegister(TAS5760L_ADDRESS, TAS5760L_VOLCONFIG, B10000011);
// Configure un-mute registers
void unmuteRegisters() {
	writeRegister(TAS5760L_ADDRESS, TAS5760L_VOLCONFIG, B10000000);
// Configure volume control registers
void volumeLowSetRegister() {
	writeRegister(TAS5760L_ADDRESS, TAS5760L_LEFTVOLCONFIG, B01111001);
	writeRegister(TAS5760L_ADDRESS, TAS5760L_RIGHTVOLCONFIG, B01111001);
void volumeDefaultSetRegister() {
	writeRegister(TAS5760L_ADDRESS, TAS5760L_LEFTVOLCONFIG, B11001111);
	writeRegister(TAS5760L_ADDRESS, TAS5760L_RIGHTVOLCONFIG, B11001111);
// spkShutDown to LOW, places the amplifier in shutdown
// spkSleep to HIGH, mutes the output
void setup() {
	// Start Serial Port
	Serial.begin(115200);
	// Set pinmodes
	pinMode(redButton, INPUT);
	pinMode(greenButton, INPUT);
	pinMode(blueButton, INPUT);
	pinMode(spkFault, INPUT);
	pinMode(blackButton, INPUT);
	pinMode(yellowButtonOne, INPUT);
	pinMode(yellowButtonTwo, INPUT);
	pinMode(spkShutDown, OUTPUT);
	// Control Amplifier
	digitalWrite(spkShutDown, LOW);
	// Set microSD Card CS as OUTPUT and set HIGH
	pinMode(SD_CS, OUTPUT);
	digitalWrite(SD_CS, HIGH);
	// Configure interups
	attachInterrupt(digitalPinToInterrupt(blackButton), amplifierControlISR, RISING); // Black button
	attachInterrupt(digitalPinToInterrupt(yellowButtonOne), playerControlISR, RISING); // Yellow button
	attachInterrupt(digitalPinToInterrupt(yellowButtonTwo), micControlISR, RISING); // Yellow button
	// Initialise I2C
	if (!Wire.begin()) {
		Serial.println("Error accessing I2S Bus");
		while (true);
	// Initialize SPI bus for microSD Card
	SPI.begin(SPI_SCK, SPI_MISO, SPI_MOSI);
	// Start microSD Card
	if (!SD.begin(SD_CS)) {
		Serial.println("Error accessing microSD card!");
		while (true)
	// start I2S in
	AudioLogger::instance().begin(Serial, AudioLogger::Warning);
	// setup effects
	Serial.println("starting I2S...");
	auto config_in = in.defaultConfig(RX_MODE);
	config_in.copyFrom(info);
	config_in.i2s_format = I2S_STD_FORMAT;
	config_in.is_master = true;
	config_in.port_no = 0;
	config_in.pin_bck = I2S_BCLK_0;
	config_in.pin_ws = I2S_LRC_0;
	config_in.pin_data = I2S_DIN_0;
	//config_in.pin_mck = I2S_MCLK_1;
	config_in.fixed_mclk;
	// config_in.fixed_mclk = sample_rate * 256
	// config_in.pin_mck = 2
	in.begin(config_in);
	// Setup I2S.
	//AudioLogger::instance().begin(Serial, AudioLogger::Warning);
	// effects.addEffect(pitchEffect);
	auto config_out = out.defaultConfig(TX_MODE);
	config_out.copyFrom(info);
	config_out.i2s_format = I2S_STD_FORMAT;
	config_out.is_master = true;
	config_out.port_no = 1;
	config_out.pin_bck = I2S_BCLK_1;
	config_out.pin_ws = I2S_LRC_1;
	config_out.pin_data = I2S_DOUT_1;
	config_out.pin_mck = I2S_MCLK_1;
	config_out.fixed_mclk;
	out.begin(config_out);
	//effects.begin(config_out);
	// setup I2S based on sampling rate provided by decoder
	decoder.setNotifyAudioChange(out);
	decoder.begin();
	// begin mp3
	mp3.begin(decoder, audioFile);
	// Load initia audio file into I2S
	audioFile = SD.open("/0001.wav");
	delay(50);
	// Read amplifier error register
	tas5760lError = digitalRead(spkFault);
	delay(50);
	// Print initial settings
	Serial.println();
	Serial.print("Player control flag = ");
	Serial.print(playerControlFlag);
	Serial.println();
	Serial.print("Mic control flag = ");
	Serial.print(micControlFlag);
	Serial.println();
	// Scan for I2S addresses
	i2sAddress();
	// Display Amplifier registers
	displayRegisterValues();
	delay(50);
	// Enable amplifier
	configureDigCtrlRegisters();
	configureAnalogCtrlRegisters();
	digitalWrite(spkShutDown, HIGH);
	startUpRegisters();
	unmuteRegisters();
	volumeLowSetRegister();
	//volumeDefaultSetRegister();
	delay(50);
	Serial.println();
	Serial.print("OK to here!");
	Serial.println();
	//Serial.println("Free Heap Memory: " + String(ESP.getFreeHeap()) + " bytes");
	//Serial.println();
	delay(2000);
		return;
	delay(2000);
	// Register for a callback function that will be called when data is sent
	//esp_now_register_send_cb(OnDataSent);
	// Register peer.
	//memcpy(peerInfo.peer_addr, broadcastAddress, 6);
	//peerInfo.channel = 0;
	//peerInfo.encrypt = false;
	// Add peer.
	//if (esp_now_add_peer(&peerInfo) != ESP_OK) {
	//	Serial.println("Failed to add peer");
	//	return;
	//else Serial.println("Peer added succesfully");
	// Register for a callback function that will be called when data is received
	//esp_now_register_recv_cb(OnDataRecv);
	//delay(250);
	//myData.soundClip = 0;
	//Serial.print("Sound Clip: ");
	//Serial.print(myData.soundClip);
	//Serial.print(" : ");
	//Serial.println(playTrack);
void loop() {
	// Enable amplifier IC
	if (amplifierEnabledFlag == HIGH && amplifierEnabledFlagChanged == HIGH) {
		//digitalWrite(ledGreenPin, HIGH);
		Serial.println();
		Serial.println("Amplifer Enabled");
		startUpRegisters();
		unmuteRegisters();
	// Disable amplifier IC
	else if (amplifierEnabledFlag == LOW && amplifierEnabledFlagChanged == HIGH) {
		//digitalWrite(ledGreenPin, LOW);
		Serial.println();
		Serial.println("Amplifer Disabled");
		muteRegisters();
		shutDownRegisters();
	// Player enabled / disabled indication
	if (playerControlFlag == HIGH && playerControlFlagChanged == HIGH) {
		mic.end();
		in.end();
		decoder.begin();
		Serial.println("Player Enabled");
	else if (playerControlFlag == LOW && playerControlFlagChanged == HIGH) {
		mic.end();
		in.end();
		decoder.end();
		mp3.end();
		Serial.println("Player Disabled");
	// Mic enabled / disabled indication
	if (micControlFlag == HIGH && micControlFlagChanged == HIGH) {
		decoder.end();
		mp3.end();
		// start I2S in
		// Setup I2S out
		mic.begin(out, in);
		Serial.println("Mic Enabled");
	else if (micControlFlag == LOW && micControlFlagChanged == HIGH) {
		mic.end();
		in.end();
		decoder.end();
		mp3.end();
		Serial.println("Mic Disabled");
		//volumeLowSetRegister();
	// Play chosen inputs
	if (playerControlFlag == HIGH && micControlFlag == LOW) {
		mp3.copy();
	if (micControlFlag == HIGH && playerControlFlag == LOW) {
		mic.copy();
	// Read amplifier error register & error handling
	//if (tas5760lError == LOW) {
	//	digitalWrite(ledRedPin, HIGH);
	//	displayFaultRegister();
	//else digitalWrite(ledRedPin, LOW);
	//if (buttonOneFlag == HIGH) {
	//	displayRegisterValues();
	//	buttonOneFlag = LOW;
	// Play clip
	if (playTrack > 0) {
		if (playTrack == 30 && longSong == HIGH) {
			// Insert clip
			longSong = LOW;
		else if (playTrack == 30 && longSong == LOW) {
			// Insert special clip
		else {
			// Insert clip
			audioFile = SD.open("/0002.wav");
	playTrack = 0;
Thanks in Anticipation!
Re: ESP32 - Guru Meditation Error: Core 1 panic'ed (LoadProhibited)
Postby Sprite » Thu Dec 07, 2023 12:59 am
Can you decode that backtrace?
CCooper1971
Postby CCooper1971 » Thu Dec 07, 2023 7:29 am
I have tried all manner of approaches to establish what’s causing this. Searches advise that the problem is caused by in illegal memory call, caused here: excvaddr:%200x0000004c in the error.
I have removed the interrupts, changed the order of the setup, ensured enough memory remains. Tried different IDEs to see if I get more information (Mostly I work in Visual Studio 2022 with Visual Micro Plug in).
Thx
Postby Sprite » Thu Dec 07, 2023 8:32 am
Okay. Can you decode that backtrace?
CCooper1971
Postby CCooper1971 » Thu Dec 07, 2023 4:30 pm
Not sure how to do that specifically. I have purchased an ESP Prog, which I’ll configure over the weekend to see if I can come up with any indicators.
What’s annoying is that the system works as an I2S system, or I can use ESP Now, but as soon as I bring them together, I get the boot loop. Therefore it has to be something in the ESP Now library which doesn’t like the Audio Tools library.
Regards
Christopher
Postby Sprite » Fri Dec 08, 2023 5:29 am
You probably want https://github.com/me-no-dev/EspExceptionDecoder .
CCooper1971
Postby CCooper1971 » Fri Dec 08, 2023 8:59 pm
Although I haven't solved it with this method, at least there has been a positive already, as it turns out that Visual Studio with Visual Micro includes an Exception Error system as standard!
Unfortunately, it simply points me to what I already knew, which his that the error occurs at this point in the code:
		return;
This is the output from the Exception Error Reporting Tool:
Exception:Error:
??:?:::0x400f3098:esp_now_init
/builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/machine/xtensa/strlen.S:84:::0x40087b7d:strlen
/builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/src/newlib/newlib/libc/machine/xtensa/strlen.S:96:::0x40087b8d:strlen
??:?:::0x400f3095:esp_now_init
.....\I2S Test Project/I2S Test Project.ino(795): error 0x400d5500:setup()
.....\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.14\\cores\\esp32\/main.cpp(42): error 0x400db04a:loopTask(void*)
0x40078000: ?? ??:0
??:?:::0x40080400:_init
0x400805f0: ?? ??:0
For a sanity check, I once again commented out the above and my sketch works flawlessly for I2S inputs and outputs on two I2S channels. Also reading from SD card via the SPI bus and the Amplifier is controlled is registers using I2C.
lbernstone
Postby lbernstone » Fri Dec 08, 2023 10:54 pm
Does esp_now work if you don't enable all these other devices? That sort of strlen error could definitely come from a function that doesn't do proper checking to make sure memory was allocated. I would take a look at your stack and heap usage just before you init esp_now to see if something is exhausted.
Here's how I usually check heap memory.
You can track stack memory with uxTaskGetStackHighWaterMark(NULL). Note that it is an inverse, so you need to know how much memory is in your stack (the default is 8192).
You can increase your stack memory by defining ARDUINO_LOOP_STACK_SIZE
CCooper1971
Postby CCooper1971 » Sat Dec 09, 2023 5:58 pm
Apologies to anyone who has read this and tried to help, but I have figured out the issue. One line of code which I had missed as follows:
	// Set device as a Wi-Fi Station.
	WiFi.mode(WIFI_STA);
CCooper1971
Postby CCooper1971 » Tue Dec 12, 2023 5:22 pm
Hi All,
Unfortunately, this wasn't the fix I thought it was. Yes, it stopped the boot loop, but that is only while the USB lead is connected.
The boot loop returns as soon as you remove the USB lead, with the same error which is, as soon as it gets to ESP_NOW_INIT, the ESP reboots.
What is fascinating is that when you either disable or insert the WiFi.mode(WIFI_STA), the sketch does run with the USB lead inserted. As soon as you remove the USB lead, it reboots.
Before anyone says it’s a power problem, it isn't, as I have thoroughly discounted it.
Any help once again appreciated.
Regards,
Christopher
