My esp32doit-devkit-v1 (powered from stable 5V supply on VIN), programmed with platformio setup (espressif32@6.4.0, arduino) is supposed to run 24/7, monitor one GPIO and send me a mail upon changes. However - there is a problem with the WiFi connection and I'm out of ideas even whether it's caused by hardware or software issues.
Typically it works well for days, surviving several channel changes made by the WiFi router where it is connected to.
But once in a while, it cannot reconnect after such event anymore. The WiFi router (a Fritz!Box 7490) in this situation logs a "interference detected on channel X" (where X is the channel that *was* active before the change).
My debug output (on Serial) in this case ends like
08:26:50 - WL_CONNECTED 192.168.2.112 ch=6 rssi=-49
[WiFi-event] event: 5 Disconnected from WiFi access point (ARDUINO_EVENT_WIFI_STA_DISCONNECTED)
08:28:50 - WL_CONNECT_FAILED
[WiFi-event] event: 9 Lost IP address and IP address is reset to 0 (ARDUINO_EVENT_WIFI_STA_LOST_IP)
08:29:50 - WL_IDLE_STATUS
...Does this description ring any bell..? any ideas?
Thanks in advance!
Kolja
