f_findnext couldnt search fully files in directory
abcdcadb
Postby abcdcadb » Mon Aug 07, 2017 1:41 am
Hi all,
On ESP32 platform, I tried to build a SAMBA transferal files app, the source code I employed is at here:
http://members.inode.at/anton.zechner/az/AzSmb.en.htm
I replaced the sysfindnext function on their linux system into f_findnext function on espidf RTOS library, my code works well but it doesn't show fully files in my shared directory (f_findnext coulnt search out somes of files on shared directory).
it seems related to the limitation of hardware?
thanks for any advice
igrr
Re: f_findnext couldnt search fully files in directory
Postby igrr » Mon Aug 07, 2017 7:07 am
The implementation of SysFindNext uses readdir_r function, which is supported in IDF. So you don't need to replace that with FATFS f_findnext, i think.
P.S. also make sure you don't use this SMB library in conjunction with WiFi/BT features of the ESP32 for production code (unless you have obtained the commercial license from the author).
abcdcadb
Postby abcdcadb » Tue Aug 22, 2017 9:43 am
Thanks, I fixed it.
That is a limitation the number of files showed from the source I used
Users browsing this forum: Amazon [Bot], Applebot, Baidu [Spider], Semrush [Bot] and 3 guests
