I was able to get smart config on my esp32 running (at least as far as I can tell), but I am unable to transmit the AP name/pw via the android app. I expect this is related to the smart config version '2.6.3' in the SDK and the last update for the android app is '2.4'. The problem is that I can't find any documentation of the communication protocol. Should the app be working and I am doing something wrong. Or is there somewhere a documentation for the protocol?
ESP Log:
I (2705) wifi: frc2_timer_task_hdl:3ffbc828, prio:22, stack:2048
I (2705) wifi: Init lldesc rx mblock:25
I (2705) wifi: Init lldesc rx ampdu len mblock:7
I (2705) wifi: Init lldesc rx ampdu entry mblock:4
I (2715) wifi: pp_task_hdl : 3ffc96e0, prio:23, stack:8192
I (2715) wifi: mode : sta (24:0a:c4:03:02:bc)
I (3225) smartconfig: SC version: V2.6.3
I (7435) wifi: ic_enable_sniffer
End the status is in 'SC_STATUS_FIND_CHANNEL'
Smart config not working with android app
Re: Smart config not working with android app
I also get this problem, does anyone can give some suggestion?
I stopped considering smart config for now as an option.
I did later on a test where I used my phone as an access point and was able to perform smart config.
It seems like that my normal AP is blocking it or something like this.
Did you later figure out why smartconfig was not working for you?
I'm running into the exact problems you had.
Has anyone solved this problem with smartconfig using ESP Touch?
