Code Generation fails within PlatformIO
sans-ltd
Postby sans-ltd » Thu Jan 11, 2024 1:17 pm
we are currently trying to get the code generation for some proto files working in our project.
We followed https://docs.espressif.com/projects/esp ... generation and added the following lines into out component CMakeLists.txt:
idf_component_register(SRCS
    "main.cpp"
    "protocol.pb.cc"
message(WARNING "COMPONENT_LIB '${COMPONENT_LIB}'")
add_custom_command(
    WORKING_DIRECTORY ${COMPONENT_DIR}
    DEPENDS protocol.proto
    COMMAND echo XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    COMMAND protoc --proto_path=${COMPONENT_DIR} --cpp_out=${COMPONENT_DIR} protocol.proto
    OUTPUT ${COMPONENT_DIR}/protocol.pb.cc ${COMPONENT_DIR}/protocol.pb.h
add_custom_target(
    generate_protobuf
    DEPENDS ${COMPONENT_DIR}/protocol.pb.cc ${COMPONENT_DIR}/protocol.pb.h
add_dependencies(
    ${COMPONENT_LIB} generate_protobuf
set_property(DIRECTORY "${COMPONENT_DIR}" APPEND PROPERTY
     ADDITIONAL_MAKE_CLEAN_FILES protocol.pb.h protocol.pb.cc)
The used versions are:
PACKAGES:
 - framework-arduinoespressif32 @ 3.20005.220925 (2.0.5)
 - framework-espidf @ 3.40402.0 (4.4.2)
 - tool-cmake @ 3.16.4
 - tool-esptoolpy @ 1.40201.0 (4.2.1)
 - tool-ninja @ 1.7.1
 - toolchain-esp32ulp @ 1.22851.191205 (2.28.51)
 - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
When we try to build it, we get the following issues:
*** [.pio/build/esp32dev/src/protocol.pb.o] Source `src/protocol.pb.cc' not found, needed by target `.pio/build/esp32dev/src/protocol.pb.o'.
The .pb.cc and pb.h files are not generated.
We had a look into the generated build.ninja file and could not find a dependency between __idf_src and generate_protobuf, as if the add_dependencies was ignored.
What is wrong here?
Thanks in advance
Florian
egionet
Re: Code Generation fails within PlatformIO
Postby egionet » Sat Mar 29, 2025 11:32 am
I am having a similar problem with add_custom_command and add_custom_target, they aren't triggering for me either in PlatformIO.
Did you figure out what was causing your problem with PlatformIO?
Regards,
Eric Gionet P.Tech.(Eng.), CIOTP, SMIEEE
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
