Which ESP32 should I choose
christianw
Postby christianw » Thu Apr 27, 2023 9:03 pm
I have a project to build a system with 4 force sensors and HX711 modules. I'm looking for an ESP32 that will allow me to :
  • retransmit the instantaneous values via a web interface through wifi
  • records a hundred values for each sensor every 0.1 s
  • retrieve the values via the same web interface.
Which variant of the ESP32 is the most suitable?
Christian
LeiaOrgana
Re: Which ESP32 should I choose
Postby LeiaOrgana » Sat Jan 13, 2024 8:01 am
Hi, have you found answers?
I may help you if you need more help.
Users browsing this forum: Semrush [Bot], trendictionbot and 1 guest
