JTAG debuggers
JTAG debuggers
I've been trying to get my Olimex ARM-USB-OCD (not the -H version) to function with OpenOCD and my Sparkfun ESP32 Thing, but to no real success. While I've managed to get OpenOCD to communicate with the device, all it does is complain about it seeing all zeroes and I'm having lots of issues getting VM-Ware to connect it to the VM with my Ubuntu installation.
What JTAG debug device are you using, and in what environments?
Re: JTAG debuggers
I took the easy way out and bought the WROVER Dev Kit from Espressif. For $50 you get:
- A WROVER module containing an ESP32 and 4MBytes of pSRAM
- An LCD display
- A microSD connector
- Exposed GPIOs (top and bottom)
- A camera connector
- An RGB LED
- An on/off switch
- ... and a DUAL port/one connection USB socket that provides TWO serial ports to your PC. One serial port for flashing/console and the other for simultaneous JTAG.
Re: JTAG debuggers
Yeah, well.. I can't base my design on the Wroover kits, can I? And I need to be able to debug on the final version of my H/W.
Re: JTAG debuggers
ESP-WROVER-KIT has JTAG header exposed, so it can be connected the the final version of H/WYeah, well.. I can't base my design on the Wroover kits, can I? And I need to be able to debug on the final version of my H/W.
Regarding separate adapters:
* Olimex ARM-USB-OCD-H, works with "adapter_khz" at 26 MHz - https://esp32.com/viewtopic.php?f=13&t=2525#p12056
* I see Segger J-Link used quite often - https://gojimmypi.blogspot.com/2017/03/ ... esp32.html
* Several people use TUMPA - https://esp32.com/viewtopic.php?f=13&t= ... mpa#p12285
Re: JTAG debuggers
Anyone happen two know if the "unlimited breakpoints in flash" of Jlink also works for Xtensa MCUs, i.e. the ESP32?
Re: JTAG debuggers
I'll answer myself: No, high level functions are only supported with the cores listed here: https://www.segger.com/products/debug-p ... d-devices/
Re: JTAG debuggers
So I managed to make some progress with my Olimex ARM-USB-OCD device, but am currently stuck with the following errors.
I run OpenOCD with the following command and the config is as below:
As you can see, I've lowered "adapter_khz" as far as it can go and I'm still having issues. Ideas anyone, besides tripple checking the wiring?Open On-Chip Debugger 0.10.0-dev-gcc5b0f7 (2017-08-10-17:21)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 1 kHz
force hard breakpoints
Info : clock speed 1 kHz
Info : esp32: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32: Core was reset (pwrstat=0xFF, after clear 0xFF).
Error: cpu0: esp32_fetch_all_regs (line 163): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 163): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 163): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: cpu0: esp32_fetch_all_regs (line 190): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 190): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 190): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: Exception reading pc!
Info : Target halted. PRO_CPU: PC=0x00000000 APP_CPU: PC=0x00000000 (active)
Error: cpu0: xtensa_write_memory (line 696): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_write_memory (line 696): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_write_memory (line 696): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : esp32: Failed writing 4 bytes at address 0x3FF5F064, data - a1, 3a, d8, 50, a1, 3a, d8, 50
embedded:startup.tcl:21: Error:
in procedure 'init'
in procedure 'ocd_bouncer'
in procedure 'flash'
in procedure 'esp_core_halt'
in procedure 'esp32' called at file "./tcl/target/esp32.cfg", line 44
at file "embedded:startup.tcl", line 21
./src/openocd -s ./tcl -f tcl/interface/ftdi/olimex-arm-usb-ocd.cfg -f ./sparkfun-esp32-thing.cfg
# The ESP32 only supports JTAG.
transport select jtag
# The speed of the JTAG interface, in KHz. If you get DSR/DIR errors (and they
# do not relate to OpenOCD trying to read from a memory range without physical
# memory being present there), you can try lowering this.
# On DevKit-J, this can go as high as 20MHz if CPU frequency is 80MHz, or 26MHz
# if CPU frequency is 160MHz or 240MHz.
adapter_khz 200
# If single core debugging is required, uncomment the following line
set ESP32_ONLYCPU 1
# To disable RTOS support, uncomment the following line
# set ESP32_RTOS none
set ESP32_FLASH_VOLTAGE 1.8
# Source the ESP32 configuration file
source [find target/esp32.cfg]
Re: JTAG debuggers
I've tried both, same result.I think should be 3.3v for esp32 thingset ESP32_FLASH_VOLTAGE 1.8
