Task wdt triggering while eventgroupwaitbits in task
Lavanya20
Postby Lavanya20 » Thu Feb 01, 2024 7:58 am
I have created a task with xEventGroupWaitBits, to set the eventbit i using rtos timer callback function for every 10 sec. But I'm receiving task wdt trigger for every 5 sec.
xTaskCreate(Task, "Data Collector Task", 2048, NULL, configMAX_PRIORITIES, NULL) == pdTRUE;
dataTimer = xTimerCreate("Timer", 10*1000, pdTRUE, (void *)0,(TimerCallbackFunction_t)TimerCallBack);
xTimerStart(dataTimer, 0);
static void Task(void *pvParameters)
EventBits_t eventRecieved = 0;
while(1)
eventRecieved = xEventGroupWaitBits(dataEvent, Flag, pdTRUE, pdFALSE, portMAX_DELAY);
if((eventRecieved & Flag) == Flag)
static void TimerCallBack(TimerHandle_t xTimer)
xEventGroupSetBits(dataEvent, Flag);
1.How should I avoid this task wdt ?
2. Any other way to handle wdt without deleting it?
Re: Task wdt triggering while eventgroupwaitbits in task
Postby Sprite » Thu Feb 01, 2024 8:28 am
Doesn't look like your issue is in the snippet that you posted.
MicroController
Postby MicroController » Thu Feb 01, 2024 9:38 am
You sure about that?
 xTimerCreate("Timer", 10*1000, ...
That's 10000 OS ticks, i.e. 10000/100=100 seconds with the default tick rate of 100Hz.
Users browsing this forum: Qwantbot, Semrush [Bot] and 4 guests
