ESP32 FOTA Issue
SanathRaiAjja
ESP32 FOTA Issue
Postby SanathRaiAjja » Fri Feb 16, 2024 11:07 pm
I am working on ESP32-S3-WROOM-1 Chip for one of our IOT application.
I am trying to load the bin file from S3 bucket to ESP32 via FOTA using the esp32FOTA.execOTA();
In the Below part of the code from esp32 FOTA library source file esp32FOTA.cpp i am seeing the code is getting aborted after written is not equal to fwsize.i am not getting what exactly is the issue.
Can anyone explain this to me?
size_t written = F_writeStream();
if (fwsize == UPDATE_SIZE_UNKNOWN) // match compressed fw size to responce length
fwsize = updateSize;
if ( written == fwsize ) {
Serial.println("Written : " + String(written) + " successfully");
updateSize = written; // flatten value to prevent overflow when checking signature
} else {
Serial.println("Written only : " + String(written) + "/" + String((int)updateSize) + ". Premature end of stream?");
F_abort();
return false;
Regards,
Sanath
