Azure IoT Hub no SDK - TLS read error :-0x004C
Gienek
Postby Gienek » Tue Feb 27, 2024 1:45 pm
I have done registration to DPS, procedure of refreshing SAS tokens and sending telemetry to IoT HUB. It worked for some time. After several days it stopped working. There was several failures. One success and then no more success.
I isolated problem by writing desktop Pyton script which is really bulletproof - every time sends telemtry properly. I use the same data: device id, username, password from Python code in my ESP-IDF C code. And cannot connect.
The minimal example is example of MQTT ssl with pem file from my Azure hostname, and credentials from Python script.
Code: Untitled.c Select all
    const esp_mqtt_client_config_t mqtt_cfg = {
.broker = {
.address.uri = CONFIG_BROKER_URI,
.verification.certificate = (const char *)broker_pem_start,
.session = {
.keepalive = 240,
.protocol_ver = MQTT_PROTOCOL_V_3_1_1
.credentials = {
.client_id = "theendisreal_1",
.username = "XXXXXXXXXXX.azure-devices.net/theendisreal_1/?api-version=2018-06-30",
.authentication.password = "SharedAccessSignature sr=XXXXXXXXXXX.azure-devices.net%2Fdevices%2Ftheendisreal_1&sig=ZZZZZZZZZZZZZZZZ&se=1709043213"
And log is this:
Code: Untitled.txt Select all
I (6413) MQTTS_EXAMPLE: Other event id:7
I (7293) MQTTS_EXAMPLE: MQTT_EVENT_CONNECTED
I (7293) MQTTS_EXAMPLE: sent subscribe successful, msg_id=45317
I (7293) MQTTS_EXAMPLE: sent subscribe successful, msg_id=37869
I (7293) MQTTS_EXAMPLE: sent unsubscribe successful, msg_id=20820
I (7323) MQTTS_EXAMPLE: MQTT_EVENT_SUBSCRIBED, msg_id=45317
I (7323) MQTTS_EXAMPLE: sent publish successful, msg_id=0
I (7363) MQTTS_EXAMPLE: MQTT_EVENT_SUBSCRIBED, msg_id=37869
I (7363) MQTTS_EXAMPLE: sent publish successful, msg_id=0
I (7363) MQTTS_EXAMPLE: MQTT_EVENT_UNSUBSCRIBED, msg_id=20820
E (12513) esp-tls-mbedtls: read error :-0x004C:
E (12513) transport_base: esp_tls_conn_read error, errno=Socket is not connected
E (12513) mqtt_client: esp_mqtt_handle_transport_read_error: transport_read() error: errno=128
I (12523) MQTTS_EXAMPLE: MQTT_EVENT_ERROR
I (12523) MQTTS_EXAMPLE: Last error code reported from esp-tls: 0x0
I (12533) MQTTS_EXAMPLE: Last tls stack error number: 0x4c
I (12543) MQTTS_EXAMPLE: Last captured errno : 0 (Success)
E (12543) mqtt_client: mqtt_process_receive: mqtt_message_receive() returned -1
I (12553) MQTTS_EXAMPLE: MQTT_EVENT_DISCONNECTED
After passing expiered password made out of expired sas token i got:
W (7383) mqtt_client: Connection refused, not authorized
I (7383) MQTTS_EXAMPLE: MQTT_EVENT_ERROR
I (7383) MQTTS_EXAMPLE: Connection refused error: 0x5
After passing bad certificate I got other error:
E (6603) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x2700
I (6603) esp-tls-mbedtls: Failed to verify peer certificate!
E (6613) esp-tls: Failed to open new connection
E (6613) transport_base: Failed to open a new connection
As I mentioned it worker once after some time. I tried 2 WiFi and one mobile hotspot. I tried WSS - the same. DPS is working everytime over MQTT SSL/TLS. Ive seend this: https://github.com/espressif/esp-aws-iot/issues/160
I know there is SDK for C, and example for FreeRTOS but to be honest, this code is a mess. And also had the same problem with thransport.
What could cause this error?
Gienek
Re: Azure IoT Hub no SDK - TLS read error :-0x004C
Postby Gienek » Mon Mar 04, 2024 7:58 am
I made one test - tried to connect, send, reconnect. After setting refresh_connection_after_ms:
    mqtt_cfg.network.timeout_ms = 10000;
mqtt_cfg.network.reconnect_timeout_ms = 10000;
mqtt_cfg.network.disable_auto_reconnect = false;
// mqtt_cfg.network.refresh_connection_after_ms = 25000;
it started working. After commeting out it seems to be fixed also.
I have theory: server drops connection if the device is connected for too long or has activity too often.
I'l write code to connect only if needed. If someone has any idea I'l be gratefull :)
funczz
Postby funczz » Wed Jun 26, 2024 1:46 am
Can you provide the complete code to solve this problem?
Users browsing this forum: Amazon [Bot], Baidu [Spider], PetalBot, Semrush [Bot] and 4 guests
