Blue LED Blinks, Always
fester225
Postby fester225 » Tue Feb 27, 2024 4:05 pm
When I plug in my new ESP32-WROOM-DA, I get a red solid LED. When I program it, I get a blue flashing LED. Arduino IDE (2.3.2) says it's doing a "Hard resetting via RTS pin...", and it's been saying that for 10 minutes. ChatGPT says this behavior should last less than one second. So far I haven't found any documentation saying otherwise.
Is this normal? Until I hear otherwise, I'll let it run. Maybe it really takes this long for a first boot.
On the previous new ESP32-WROOM-DA the same thing happened. Power off, then on brought back the blinking blue LED. Doing a power-on from the charge only socket gave the same result.
Re: Blue LED Blinks, Always
Postby Sprite » Wed Feb 28, 2024 1:48 am
Erm... Not sure what hardware you're talking about, but the ESP32-Wroom-DA does not have any LEDs.
MicroController
Postby MicroController » Wed Feb 28, 2024 11:31 pm
That's usually the last message output by the flashing tool after flashing is done, right before the tool exits and your program starts running on the microcontroller.
[An LED blinking after flashing]
Is this normal?
If you flashed a 'blink LED' example program, the "Hello World" of microcontrollers for checking if the toolchain and hardware is operational, then a blinking LED would be a common experience.
fester225
Postby fester225 » Fri Mar 01, 2024 12:31 am
Great idea.
Blink works. I can vary the blink rate so I'm sure the program is installed and working.
What's next?
