WebServer.h how do i know if a client disconnects?
PepeTheGreat
Postby PepeTheGreat » Sun Mar 17, 2024 8:32 am
My video streaming app does use server.sendContent(); to stream mjpeg pictures. This is done in a loop inside the webserver handler. This loop continues to send even if the client disconnects. How do i prevent this?
Using "WiFiServer" there is client.available() and client.connected() to check this.
Using "esp_http_server.h" the httpd_resp_send_chunk function gives the return ESP_OK on sucess.
How do i replicate this functionality with "WebServer.h"?
Or can i make the OTA updater functional with "WiFiServer" or "esp_http_server.h" ?
lbernstone
Re: WebServer.h how do i know if a client disconnects?
Postby lbernstone » Sun Mar 17, 2024 7:25 pm
I am not so familiar with the code to have a quick answer for you, but the WiFiClient that WebServer is using is public, so in theory you should be able to look at that object to see if it is connected.
As far as an IDF-based wifi manager, esp-wifi-manager can be included in a project as a component.
PepeTheGreat
Postby PepeTheGreat » Mon Mar 18, 2024 1:52 pm
TY. That might exceed my talent. Will try.
Project:
http video:
https://youtu.be/NCWrQaDqzJg
external video:
https://youtube.com/shorts/Xo_1b1SBKy8
lbernstone
Postby lbernstone » Mon Mar 18, 2024 7:39 pm
#include <WebServer.h>
WebServer server(80);
void handleRoot() {
  WiFiClient wfc = server.client();
  if (wfc.connected()) {
    Serial.print("Remote IP: ");
    Serial.println(wfc.remoteIP());
  server.send(200, "text/plain", "Hello!\n");
void setup() {
  Serial.begin(115200);
  WiFi.begin("larryb","clownfish");
  WiFi.waitForConnectResult();
  server.on("/", HTTP_ANY, [](){handleRoot();});
  server.begin();
void loop() {
  server.handleClient();
  delay(100);
PepeTheGreat
Postby PepeTheGreat » Mon Mar 18, 2024 9:11 pm
  while(wfc.connected())
Works perfectly. TY
Next thing is mounting esp32cam on this:
Users browsing this forum: No registered users and 7 guests
